Question about Tricity Bendix SE454 Electric Kitchen Range
Fan oven is noisey
The fan oven has started to make a loud noise in use, although sometimes on opening the oven door it becomes much quieter, only to resume when the door is closed again.
  • 249 Answers
Needs new fan motor unless the old one is loose
Posted on Dec 12, 2008
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Ariston fridge/freeser BCB31AA
Call out the warranty supplier. Where is the noise coming from? If no warranty, check the electrics to the compressor and fan. sometimes the noise is the fan. Also switch off overnight and leave doors open. When restarting, if the noise has gone it will have been the internal fan hitting on ice buildup.
Mar 25, 2014 | Freezers
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to
Hope this is helpful
May 17, 2011 | Ovens
Dell optiplex GX620 loud processor fan noise like a vaccum. I upgraded to windows 7 and also upgraded to 4gb of ram and a new hd video card as well as a 1tb hd. I bought 4 more gbs of ram but windows...
I don't think you can install 8gb of ram into that desktop. If the processor fan is too loud check it for dust or any other obstructions. If there aren't any try replacing the fan - it could be a bearing in the fan.
Mar 06, 2011 | Dell OptiPlex GX620 PC Desktop
I just purchased an 03 Trailblazer LS 4x4, the salesman said it has an electric fan, which I'm not familiar with. Is it supposed to be loud when accelerating? It does seem to "shift" down as the vehicle...
Siunds more like a visous clutch fan. It's bolted tho the water pump hub and belt driven. Electric fans are attached or mounted against the radiator and are driven by an ekectric motor that is relay controlled. Electric is quieter, yet can be heard when they kick in. Only because it is at an idle or low speed.VC fans can be very noisey depending onwhar srage of engagement it's in. Both fans are negated by the ram air effect at speeds above 35 mph. If your fan is noisey throughout the acceleration and shift range and variable levels of noise are exoerienced in down sgifting, You have a viscous clutch fan.
Jun 11, 2009 | 2002 Chevrolet TrailBlazer
Loud fan sound when fridge door is closed
I just vacumed my fan and everything else that I could get to. The refrigerator runs much quieter.
Mar 11, 2009 | Samsung Refrigerators
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Tricity Bendix SE454 Electric Kitchen Range Logo
383 people viewed this question
Top Tricity Bendix Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tricity Bendix Kitchen Range Expert? Answer questions, earn points and help others
