Question about HP Compaq nx6110 PC Laptop
Slow Hi again, now iam on wireless, but my computer is very very slow, is somethonk i do rongk? Whose
  • Whose Matose Dec 11, 2008
    This I do thank you mani time
    Whose :-)
  • Obiora Micheal
    Obiora Micheal May 11, 2010
    please explain if it is your internet connection that is responding slowly or your laptop computer so that i can give you a good solution
  • 340 Answers
Hi Whose,
Me again :-)
Yes m8, there is something you can do.
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start
à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Posted on Dec 11, 2008
Hi i have realtek RTL 8187 wireless adapter, and when i watch in my antenna managing program, connection is quality and signal streght about 80% THATS GOOD. always was good connection, but now yellow and...
somebody is accessing your wireless network and getting free internet service from you unless you had setup a wep security! if you have an un-secure network then anybody with a wireless adapter can access your network and access your internet free and drag down the speed of your internet connection.
however, if you do have wep enabled and there is more than one computer connecting then this will slow your connection down as well. please remember that there are some games and gaming sites that are bandwidth hogs and will slow down other computers connection on the same network. also watching streaming videos and gaming at same time can slow down connections as well.
Aug 25, 2011 | Toshiba Realtek RTL8187B Wireless...
My connection is very slow,it is smart broaband
hi there, you don't need a router for smart broadband or other wireless broadband, cause all wireless broadband is already routed, if you used a router the connection will slow down due to NAT and built firewall of your router. Option: If you want to share your internet connection to other computer, used a HUB switch this would be better. thanks
Apr 30, 2011 | Computers & Internet
Hi, I recently purchased this netgear device, I managed to get it working, however it is very slow and once I logged off, I have to start over again, changing firewall settings and fiddling around to get...
HI friend,
let me explaing you how this works your wireles adpater is gonna work as a receiver and what ever brand router or modem wireless you have it would work as receiver so you can try make some wireless changes in the router contact your your router vendor and say you got slow connection and disable the firewall in router and assign global DNS 4.2.2.2/4.2.2.1
Sep 27, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
Computer was working fine but slow uninstalled
possibly you uninstall your wireless driver try checking in device managerunder netwrok adapters for the driver if you don't see anything saying 802.11 wireless network adapter then you will have to install the drivers again for your wireless card on the system. ^_^ your drivers should be downloadable in the website of your OEM ^_^
Jun 04, 2010 | Toshiba Satellite M35X-S161 Notebook
Extremely slow internet connection and computer navigating
Extremely slow internet connection and computer due to registry corrupt.
The Windows registry is a database repository of information about a computer's configuration.
clean registry here
http://www.keep-pc-clean.com/
May 25, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
Still SLOW after a complete recovery (with disk) the computer
hello!!! your computer slow maybe some files is missing due to slow performance
or when you virus scan last time some of your files in the drive c are infected by the virus
and the anti virus normally he do to delete automatically whose files unable to repair by
anti virus scaner your best to do to reformat using os/operating system cd, or try upgrade your memory ram...
thank you!! hope i can help you..have a good day!!!
Jul 06, 2009 | Sony VAIO VGN-FS550 Notebook
Slow internet
90kbps is a little slow. You should be getting closer to 175-200kbps. You have to remember also that the ISP only states that the speeds are "up to 1.5mbps", so that could mean that you get less than that.
I would try and run a speed test. Go to http://www.speakeasy.net/speedtest and run a speed test. If you're getting an optimal connection you should get results for download at 1300+ kbps. If it's much less than this I would restart your networking equipment one time and test again. If there is no change I would contact ATT and have them test the lines.
Hope this helps.
MO
Jul 09, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Wireless connection/will not connect
reinstall your wireless driver send your laptop model number i will send drivers
Nov 05, 2007 | Acer Aspire 5050-3242 Notebook
HP Compaq nx6110 PC Laptop Logo
102 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
