Question about Linksys Wireless-G WRT54G Router
Linksys stop working have it for many yers - Linksys Wireless-G WRT54G Router
  • Whose Matose Dec 11, 2008
    Its working, now I can work wireles, thank you
    tkankyuo
    Whose
    Scholar:
  • 80 Answers
Please clarify your problem. Stop working mean it is not getting power on or problem in getting connectivity. if you r facing power problem please check whether its power plug is ok or not. and if connectivity is the issue than first of all connect the wireless router to your system through lan cable and than try to get access the router by automatic ipaddress you wil be assign the ip of the same range. than open the gateway address in the browser and try to restore it to factory default setting. and than reconfigure it.
Posted on Dec 11, 2008
  • 340 Answers
Hi there and welcome to FixYa
All you have to do is to reset your router.
You unplug it, wait a few sec.
then fire it up again.
/Teis
Good day it Mrs J Meyer Riccardo Meyer Membership number 37231605.
Yer right, yer being ripped off. Best you ring ya bak an tell em to stop all payments right now, then ring the gym an tell em they ripped you off and you want yer money back with interest or you'll git yer lawyer on to them and sue there arses off. when you git yer money back cancel the membership and tell all ya friends what happened.
Nov 16, 2017 | HIS Computers & Internet
After the last update i got nothing black screen says my memorey is not enough been playing 4 a long time lost 16 cars have 2 retweak everyone agin time cosuming what happen i know the game did work
Well Steel, l reckon yer stuffed, what you should do is shift yer lazy a$$ of the couch an git yerself ofta skool and learn howda spell right fer a start..Now do ya have enough memory in yer machine? a decent graphics card? and do ya know watcha doin?
Dec 04, 2017 | SteelSeries Audio Players & Recorders
At a full stop the truck idles at about 5rpm and is very difficult to get into gear. i just got the clutch replaced and it still does it
It still does it cause yer clutch don't put yer engine at 500 rpm. Check timing or throttle position.
Apr 23, 2011 | 1995 Toyota Pickup
Dont know how to set clock
hold sel for a few seconds then search threw using yer skip up and skip down button. untill u hit clock H then use yer volume botton to change.... then hi yer skip up again untill u hit clock M and use yer volume again. then hit sel to finish.
Nov 19, 2009 | JVC KD-G140 Car CD Player
Can't set clock i have a jvc kd-g140
Nvidia 9500gt is displaying rainbow colored layered skies and smudgy stars at night skiesand I seem to have a hesitation now for a while. I ran scndsk chkdsk several virus tools and "error free" I've...
Tools - 1 Monitor /1 - 2 can's of "blow off"
- clearnail polish razor and blowdryer depending
trouble shoot----
Just for giggles try locating another (cheap) but confirmed working monitor. ive had this problem as well and i did exactly as yer doing just to discover it was the monitor and thinking it had to be a solftware issue:P
if its solfware then ill need more clarification of the proggys yer running now, what game, what patch, which version, what u were running before the problem occured.. its possible you may have swollowed a update that your program/server hasn't updated itself for yet. card's and solfware and be tricky bisness:))
I alwase keep a confirmed (CRT) old school working monitor in my closet just for theas problems:) you also mite try wiggling the cable leading to your vid card and see if the colors change as you are wiggling the plug, if thats the case, the problem is between yer plug and card, thus you should be able to determin which side sustaind the damage under visual inspection...check both male and female sides.
1) If yer still having issues and you've confirmed that its the card and not the monitor then remove the side wall to your computer by unscrewing the 2 phillup screws, depending on yer model thay mite be bulkey bolts. now at you own risk be sure to remove any stickers "carefully" as it voides yer warrenty if you snap it in half. to do this use a blow dryer to heat the sticker and a razor to lift the edge up and pull carfully..u dont wanna loose warrente over a routine maintance procedure...
2) take note of your video card, it lays horrizontal and thus it is prone to collecting dust - with the computer off... aim yer can of and blow off the card. if you see condensation then back the can off a little, no worries the computers off right :))
3) since we r already here take note of the block looking thing with the fan sitting on top, if you dont see it this then you probably have a shroud over yer heat sink, the shroud is usually big white and plastic, and it will have to be removed -
4) with that said, this is your heatsink and fan- under the fan is yer heat sink and it has little irrogation fins that are used to pass air through and thay are probably filled with dust and causing yer system to heat up and yer computer performance to slow down.
Aim yer can at the fins beneath the fan and blow out all debries in theas fins, try not to breath this stuff !!!
5) Now blow off all wires, fans, motherboard (the thing yer heatsink and fan is attached too) and memory AKA RAM (the vertical stick things that attach to the motherboard) blast away untill all is clean. if your feeling confident you can take the heatsink fan off via the 4 screws and directly blow off the heatsink, just dont apply too much pressure here.
6) Reassemble the shroud to yer fan (if equipped) throw on the side wall, and rember that sticker? yea were gonna get some clear nail poilish to reapply it, and now you dont have to wait 9 weeks for your computer to come back from a overworked tecnition to do what we just did in under a hour:)))
sorry for the long and crunchy speal,ill be recycling it for others in the future:)
NOTE: if you just baught this card and did not wear a groundstrap or discharge yourself of any static electircty aka touch your computer case before installation, you could have possibly damaged your card, its rare but it happens, or u may have just gotten a bunk card and that happens too...
Hope this helps
Oct 25, 2009 | Nvidia GeForce 9500 GT, PCI Express Video...
My linksys router wrt54g worked well for last
if possible, can you go to the linksys support site and doenload a new firmware? then connect with an ethernet cable and update the firmware. If that does not help, it may be time to buy a new one.
Jun 16, 2009 | Linksys Wireless-G WRT54G Router
After six yers of flawless use, a notice comes up
try starting the tunning and restoring the programs from scratch
May 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Linksys wireless not connected to my mew HP pavioion laptop
Linksys wireless have know to go bad, return and try another one.
Nov 17, 2008 | HP Pavilion dv6000z Notebook
Linksys Wireless-G WRT54G Router Logo
24 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
