Question about Nikon D40x Digital Camera
SD Card When I try to insert the SD card into my D40X the card will go into the slot as normal but it wont click into place. It's just loose inside the slot. If I turned the camera on it's side with the Card Door open the SD card would just fall out and the camera is telling me there is no card. Any advice would be greatly appreciated. Yours Jim Dougherty
  • benhutch Dec 14, 2008
    Exact same problem
  • Anonymous May 06, 2009
    I have the same problem
Did you ever find a solution?
Posted on Jul 25, 2010
Jammed sd card in d40x
You just try the SD card pull out by tweezers. first push it once and then pull by a sharp tweezers,
Aug 29, 2012 | Nikon D40x Digital Camera
Where to insert sd card
Normally the sd card slot will be on the side or in front of the laptop if it has that option. Not all laptops have sd card slots.
If your laptop does not have the sd card slot, then you can purchase a sd card reader that plugs into your usb port on the laptop for less than $20.
Try Tiger Direct at: http://tigerdirect.com
Below is a multiformat sd card reader for $9.99 at Tiger Direct.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=186067&CatId=2825
Also your camera might have come with a cable that plugs into the camera and the other end into the laptop's usb port. Once you have the cable connected, turn the camera on and the computer will recognize it. You can then search through the camera folder for the pictures or videos. If you use this method, you leave the SD card inside the camera.
May 20, 2012 | Computers & Internet
Nikon d40xcamera...sd card won't click into slot
there is a lock on the side of some sd cards try checking if there is one.
Oct 30, 2011 | Nikon D40x Digital Camera
None of my SD cards will lock in place in my Nikon D50 camera. Is this fixable?
Do you have insert it with a wrong direction? Commonly, when you put in a SD card with a right direction, press it until the card has got to the end then loose your finger, the card will in place..
May 06, 2011 | Nikon D40x Digital Camera
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
I INSERTED THE MICROSD MEMORY CARD IN THE COMPUTER BUT I DONT KNOW WHAT TO DO NEXT
Most computers do not have a slot for a "Micro" SD card. Instead, those often have to placed inside an adapter that looks like a normal size SD Card. If your SD card looks like the picture below, you should be good to go from the start! Once it is inserted into the computer, click on "My Computer". On older Windows versions, this is a link on your desktop. In newer, click on the Start menu at the bottom left of your screen, then click on the "My Computer" option there. You should see the SD card on that screen below your hard drive.
If, however, your card looks like the smaller SD card on the right in the picture below, please ensure that your computer has a specific slot for this smaller variant of SD card. If it does not, you will need an adapter, shown to the left. In that case, you will plug the small SD card into the adapter, and then into the computer. then go to My computer to see it.
Mar 05, 2011 | Computers & Internet
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I PUSH IT INTO SD SLOT
  • Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
  • Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
  • Dec 05, 2010 | Bushnell Trail Scout 11-9500c Digital...
    How do you put your sandisk microSDHC card with adapter in your camera
    That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
    You will just have to push card in and camera will automatically read card.
    If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
    Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
    Sd card won't click into place on my Nikon d60
    Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
    Mar 11, 2009 | Nikon D60 Digital Camera
    Nikon D40x Digital Camera Logo
    329 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
