Hi, i am reformatting my PC, i noticed that there is no booting sequence in the BIOS, where can i find it. Hope that you help me with this. my board is an Intel with pentuim 4 processor. thanks
  • 2,110 Answers
Is there anything like boot device priority...
Posted on Dec 11, 2008
How do I change boot sequence on Dell XPS-410 desktop
Hit F2 on startup to get into the BIOS. Then, modify the start up sequence in there.
Hope this helps!
Mar 01, 2015 | Dell XPS 410 PC Desktop
Hi, i have an acer aspire 4755g. when i power it on, it gets stuck in the windows logo and doesn't move on to the welcome page unless press the ENTER key. I tried looking at the bios for the prima
The boot sequence has nothing to do with how this acts.
The boot sequence tells your computer what to boot from.
Here's an example of a boot order list.
1. Hard Drive
2. Optical Drive
3. USB Drive
4. Floppy Drive
If it can't detect an OS on the first one it goes to the next one on the list until it finds something that can boot.
You should try to update your computer, possibly clean it up. It could contain some sort of malware on it.
If it's an option, you should just do a reformat and that should fix all your problems up. If that doesn't fix your issues then you're going to need to get some new hardware aka bring it into a shop or buy a new laptop.
I hope this helps.
Feb 25, 2013 | Computers & Internet
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
My Laptop is Satellite L505-S5990,After i change boot sequence from booting with CD rom to HD it won't effect changes.WHy is it this way>Any tips as to why it is so and how i can change boot...
Changing boot sequence.
Go to bios setting, click "F2" upon start up( when you read the bios and HD readout ). Choose the part boot sequence, click " enter" and choose what drive will be use first.
Save the settings upon exit.
Hope FixYa helped you out!
Aug 17, 2011 | Toshiba Satellite Laptop with Intel Core 2...
Hi the pc does not have a boot sequence menu and the os is corrupt
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
this is the boot sequence first boot device floppy
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
Jul 23, 2011 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
My acer laptop turns on, then tells me to contact the systems administrator. If I try to continue it shuts down. at one time I recall reading that the files have been currupied. is there anything I can...
It sounds like the Windows boot files have become corrupted. That could happen for several reasons, but if you're willing to just reformat/reload the operating system, we're only concerned with one of those reasons.
There are some viruses that can corrupt boot files. If that's what happened, then reformatting/reloading the OS will take care of it.
On the other hand, it could be that your hard drive may be failing. When you reformat/reload, the Windows system will tell you if it finds errors on the drive.
The following is from the Acer manual for your machine as to how to access the BIOS and enable a hard disk recovery:
To activate the BIOS utility, press during the POST; while the notebook PC
logo is being displayed.
Boot sequence
To set the boot sequence in the BIOS utility, activate the BIOS utility, then select
Boot from the categories listed at the top of the screen. [You should set the CD/DVD drive to be the first boot device, in case you need to reload from a DVD]
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
[End of manual quote]
If you're not able to restore from the hidden partition on the hard drive, which may happen if the drive is damaged, then you'll have to try to restore using a Windows DVD.
Hope that's helpful.
Jan 12, 2011 | Acer Aspire 3680 Laptop
I have installed dual os(XP and Ubuntu Linux 10) on same drive It is working but my pc became very slow. Now I want to uninstall any or both os but it is showing error. So suggest me How can I?
Hi, try the following sequence.Insert your XP disk and reboot, during bootup press your ESC button or Del on some PCs, you will be in BIOS, from here you can change you primary boot drive, select CD rom, save changes and reboot. Press return when request to boot from CD appears, wait for the sequence to finish installing, select the section of the drive you wish to change, select delete, confirm and then reformat your hard drive. PC will reboot afterwards and start installing XP. Be aware this will remove everything from your hard drive, so back up first. Hope this helps
Jul 10, 2010 | Microsoft Windows XP Home Edition for PC
How to boot from windows xp cd, on msi U90 notebook, there is a boot manager runing on it, i tried to format the harddisk by removing it and installing it on another pc. but it dosent help it still runing...
u can by configure the boot sequence from ur motherboard setup u can enter motherboard setup as below 1) when u turn on the PC keep press and depress the "delete" button or "F2" button. 2)enter to BIOS section 3)move ur arrow downward till u will be at boot sequence. 4)change ur boot sequence to be firstly from ur CD-ROM
Jun 08, 2009 | MSI Wind UmNotebook
My dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Feb 17, 2009 | Dell OptiPlex GX200 PC Desktop
for formatting the system you must have a operating system cd, put it on the rom, then go to bios and select boot sequence select first boot device cd
Oct 13, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
