Question about QuickPAD IR Keyboard
Can't transfer my QuickPAD data into my computer
I plugged in the remote into a port in the front of my new Dell xp computer but can't transfer the data with the send file key.
You need an XP driver installed on your computer. Contact the manufacturer to see if they have one available to download.
Posted on Mar 12, 2009
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
We have a Windows XP system on a 14 year old Dell computer.. We are desirous of transferring data from that system to a new computor. My husband purchased an Acomdata Hi-speed 2.0 external hard drive...
If both your Dell and the hard drive have USB ports you may be able to download directly. Other wise you may purchase an external drive and load the data to that. The external drive almost certainly will connect by USB.
Nov 19, 2014 | Dell Computers & Internet
Trying to transfer files, documents and pictures from my old computer Windows XP to my new computer also windows XP, I have purchased through DELL Belking Easy Transfer cable for Windows 7. Can I use the...
Dear Friend
I will rather suggest you for the LAN instead of data transfer cable. By using LAN you can share Data, Documents, pictures, printers, faxes, and storage devices at High Speed.
Gagan
Mar 14, 2011 | Computers & Internet
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Have been using Mozilla Thunderbidr for email. Have a new computer and have Mozilla Thunderbird seet up there - would like to be able to transfer old emails (kept for reference) to the new computer. Have...
Now-a-days the storage space of an email provider is so huge that you can access them using any PC with internet unless you have deleted from the server. If so transfer all emails to a separate HDD, load your new OS and transfer the data back......................sodeep
Sep 24, 2009 | Dell Dimension 4600 PC Desktop
Problem my mac and mini dv deck when they are connected with dv ports
Hello, the mini dv is the port that carries images and video to a television for example, or a computer, but will not help to transfer data to a computer. the firewire port does transfer data to the computer though, this is the reason why it is ackowledged as an external hard drive when you plug it this way. The best is to plug both, this will give you the opportunity to watch on your desktop, and to transfer data
May 27, 2009 | Apple Computers & Internet
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Transfering data from one desktop to another through LAN connection
you have to put the cable in the ethernet card (or network card) it looks like telephone connector ( it will be big in size)
May 31, 2008 | Dell Dimension 4600 PC Desktop
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
QuickPAD IR Keyboard Logo
156 people viewed this question
Top QuickPAD Computers & Internet Experts
David Payne
David Payne
Are you a QuickPAD Computer and Internet Expert? Answer questions, earn points and help others
