Question about IBM ThinkPad R52 Notebook
Upgredation of ram
I have ibm thinkpad r52 with 256 mb ram .
I want to add 1 gb ram more . which RAM should I purchase , means
ddr1 or ddr2 and with what speed?
    President:
  • 1,073 Answers
Here are info about that:
IBM THINKPAD R52
Memory:
2 SODIMM 200-PINS Sockets
Supports DDR2 400/533 Unbuffered Non-ECC Memory
Supports maximum memory capacity up to 2GB
I recomend you to change both of them
I hope this info is helpfull for you
Good luck
Posted on Dec 11, 2008
I have a ibm rev 1.6 and I would like to know if I can put 1 gb of ram in it?
You would need to tell us what the motherboard model number is.
Apr 05, 2013 | Computers & Internet
Maximum RAM MEMORY DDR2 Capactiy
Depends on motherboard. In contemporary ones it usually supports up to 64G
Aug 07, 2012 | Asrock P4i48 Motherboard
My laptop ram is 1GB. i want to extand it. which type of ram is good for it and what is its cost?
Dear! If its RAM is not fixed and it has facility to replace the RAM, you can extend it but if the RAM is fixed on motherboard you can not extend it. There are two types of RAMs: (i) DDR1 (ii) DDR2
1GB DDR1 costs upto $30 and 1GB DDR2 costs upto $20, there may a chance of $3-$4 in prices.
Now you choose that which type of RAM your laptop has?
Aug 21, 2011 | IBM Lenovo ThinkPad R61i Notebook
I need to upgrade the RAM on my motherboard. I have a 512mb at the moment. Can I add 3 more 512mb as there are 4 slots? Will they work together or do I need to purchase one bigger card?
You can add 3 x 512 MB, or 1 x 512 MB and 2 x 1 GB. Check if you need DDR1 or DDR2.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | Computers & Internet
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
Will ibm rev1.6 motherboard will support DDR2 RAM ??????
Check the RAM slots -- in the "channel", there are small vertical "blocks", so that only *ONE* type of RAM (SDRAM, DDR1, DDR2, DDR3) will match-up the "slots" amidst the gold pins on the RAM.
Given that it's a ThinkCentre/NetVista motherboard at 400 Mhz:
http://www.shopping.com/xPO-IBM-SYSTEM-BOARD-W-O-POV-02R4087
with a Pentium 4 CPU, it's very-likely that it _only_ supports DDR1 RAM -- it's simply too old to support DDR2.
Dec 05, 2009 | IBM (02R4087) Motherboard
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
RAM for thinkpad?
T60
Memory RAM Technology DDR2 SDRAM (im sure they are the smaller modules, not normal ddr2 that goes into desktop pcs)
Installed RAM 1 GBMax Supported RAM 3 072 MB (3 GB)
Aug 18, 2008 | IBM ThinkPad T60 Notebook
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
IBM ThinkPad R52 Notebook Logo
224 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
