Question about LG DLE5977 Stainless Steel Electric Dryer
2008 LG Dryer will not heat.
I have a LG TROMM DLE5977B  Dryer, it has normal use, i purchased it new in January 2008. Today, all of the sudden it will not heat. I cleaned the filter and took the dryer vent hose off and checked for clogs etc. What should i do?
  • Anonymous Feb 07, 2009
    My lint filter got a little heavy and i know it kicks off the gas. Wheres the reset located?
  • Anonymous Mar 26, 2014
    The Dryer DLE5977B runs fine, but does not heat
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Dryer wont heat
Sounds like your heating element has went out. So you will either have to replace it $100 to $150 or purchase a new one
Nov 30, 2013 | LG Tromm Electric Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Our LG TROMM DLG7188WM dryer has no heat
Several things can be the problem.
Is 220v present @ the outlet?
Heat element?
High limit thermostat?
Main computer?
Bad dryer cord? Ect...
Proabably time for a service call.
Jan 12, 2010 | LG Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG tromm electric dryer not heating up
Most likely you have a bad electrical connection, resulting in only 120 volts to dryer. (enough to run the 120 volt motor, but not enough to power the 240 volt heating elements) Turn off breaker. Make sure wires on breaker are tight. Make sure nutral wire is tight in breaker box. Take cover off dryer recepticle and check the wires in it to make sure they are all tight. Check that the connections of the cord at the dryer are tight.
Nov 04, 2008 | Whirlpool GGW3878J Dryer
LG Dryer DLE5977B is putting out hot air,but clothes not drying. Check filter light is blinking. Nothing in lint filter. Checked entire vent system all the way outside. Nothing is obstructing it. ...
Go to www.repairclinic.com and enter DLE5977B. With luck, you will be presented with a list of common replacement parts and may be able to view a generic LG video showing disassembly. From this information, you may be able to pinpoint the cause of lint backup into your dryer.
Dec 19, 2017 | LG Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
Feb 16, 2008 | Dryers
LG DLE5977 Stainless Steel Electric Dryer Logo
764 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
