On Gateway MA7 laptop, the DVD drive does not complete the burn. Process is not fully done and windows explorer crashes when trying to view files on the drive. Explorer comes up with error message - DivX possible problem. Before DiVX files were written without a problem.
Please advise any solution or is the drive defunct.
SOURCE: divx greek subtitles
look in the menu and try to change the encoding, There should be 3 options, Unicode, Cyrilic & Greek. Select greek if the .sub or .srt file is in ANSI encoding, or select Unicode if the file is in UTF-8 or Unicode encoding.
To find out the encoding of an .srt file the simpliest thing to do is open them with notepad and got to "File" -> "Save as", The encoding should appear in the bottom of the dialog.
SOURCE: replacing dvd/cd-rom drive on gateway laptop
Depends - what gateway? the one you listed under?? Because the model you posted with already came with a DVD drive.
Reply with the model of your machine and i can probably find you help. Gateway usually has instructions on their site.
The instructions for the M305CRV are here.
That model can use pretty much any standard laptop CD if you dont mind the face not matching get a generic drive like the Sony CRX880a at
http://www.directron.com/slimoptical.html
SOURCE: IS POSSIBLE TO UPLOAD DIVX PROGRAM (PATCH) ON IT ??
Try this:
http://www.videohelp.com/dvdhacks?dvdplayer=D6230&hits=50&Search=Search
SOURCE: Cannot copy files to DVD disks
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
SOURCE: jvc kw-avx800 divx upgrade
go to ur settings. you will find a divx code. with that code you have to log on to the internet and sign up. with that code you enter it (following the instructions) then you will recieve the update, with that update it will ask you to save it to disc or removable storage device. once saved, plug it into ur jvx deck and it should update automatically.
