Question about Pioneer CDJ-800 Turntable
Displays gone on CDJ800
I have a CDJ-800. It powers up, and plays CDs with no problem (jog wheel, all buttons, etc. are fine), but both the track display and the display in the middle of the jog wheel are gone.Can I fix it myself?
Cheers
  • 7 more comments
  • basik Dec 11, 2008
    Thanks CDJ repairs,
    I appreciate the response. I live in Japan so it'd probably be easier just to send it directly to Pioneer. Again, thanks for your help.
    Cheers
  • djfabjan Dec 13, 2008
    I checked if the displays are getting power, and when i start the cdj in the dark i can see the orange glow wire's on both displays, ...
    what else could cause this??
  • hotheatt Dec 30, 2008
    Well, i have exactly the same problem.
    And the bigger problem is, i rent the cdj from a guy.
    It would take a lot of cash if i send it to pioneer i think. Or could it be not?
    Damn, i can't face the rental guy!!
    Is there some DIY solutions that can help??
    Please2..
    J.D
  • mongo69 Jan 18, 2009
    Both display's gone too! Tested and all voltages around the display driver chip seem ok. Any further suggestions anyone?
  • Birlocha Jan 21, 2009
    Same problem, it started with some strange red lines in the jog display, then suddenly the track display was not working anymore...everything else works fine, buttons, pitch, jogwheel, etc...
  • bray206 Feb 03, 2009
    Gosh!!! Man mine is doing the same thing.The light in the middle went out,of the wheel,and the digital numbers are out also.
  • muggzymain Feb 03, 2009
    How much would this cost to repair?
  • djjonk Mar 20, 2009
    My CDJ works fine except i cannot see anything on the display, nothing lights up on it. is there a simple at home way to fix this?
  • tjeerdiepeer
    tjeerdiepeer Jan 23, 2013
    i have the same. can't fix it by myself
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Check all IC links on SECB Board
Posted on Oct 08, 2013
  • 68 Answers
It sounds like a power supply to the both display pcb's is missing, unfortuanetly i wouldnt recommend attempting to fix this yourself, if you havent had it repaired then you can send it to us.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 11, 2008
800 mk 1 plays in cd mode but once vinyl button is pressed play stops. even if I press the play button. The unit still jogs fwd and back just fine in vinyl. The case i use on occasion puts pressure(maybe...
You are almost certainly correct re "pressure switches"
Pioneer call this part "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it, it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 25, 2010 | Pioneer CDJ-800 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Can you help me
Sounds like you have a broken Sheet Switch. Basically, there is a circular piece of plastic which goes underneath the jog wheel, so that when you press the wheel, it activates the switch and stops the track / slows it down, and also puts the indicator on in the middle of the wheel. The part is readily available from Pioneer, and is a bit of a tricky fit, however is not the hardest thing to fit on the unit. However, it is the most fragile part of the player, and most common to fail if the unit has had physical trauma, eg dropping, spillage etc.
Feb 28, 2009 | Pioneer CDJ-800 Turntable
Player jumps back to previous track for no reason
Have you tried cleaning the lens out? Invest in a good quality CD cleaner. IF this does not solve your problem, then you more than likely have damage to the reader, and will need to be replaced.
The part can be found here: PIONEER CDJ PART
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Pioneer CDJ-800 Turntable
CDJ800 vinyl modus
Hi Mate
My last post was a CDJ with a separate fault, causing a similar type fault.
99% of the time, this particular fault is the Flac switch under the platter jog wheel, take the jog wheel apart clean the plastic strip that runs around the jog wheel, the one with rubber feet that activates as a pressure switch.
Often there is air bubbles, liquid, condensation in between the two layers - causing it to stay in touch mode. If that doesn't fix it then you need to replace that strip (pressure switch). They are about £30 quid.
All the best and good luck
Dec 04, 2008 | Pioneer CDJ-800 Turntable
Cdj800 jog wheel stops working after 45mins
The drive motor on this unit is probably about to die, or the contact pad underneath the platter is damaged. In either case, you'll have to take it to a qualified service technician for diagnosis and repair.
- Optic
www.repairny.com
www.1200s.com
Oct 05, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
May 06, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
739 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
