Question about Welbilt MR95TW Microwave Oven
Welbilt microwave how do you set the clock? I can get the correct time in put how do you setit? thank you, Dee Dee
  • Welbilt Master
  • 9,150 Answers
You can try different combinations (where # is the number need for correct time) such as: 1. CLOCK 2. # # # # 3. CLOCK 1. CLOCK 2. # # # # 3. START 1. # # # 2. CLOCK Otherwise, if you could submit a photo of your control panel, we might be able to pinpoint it for you.
Posted on Mar 04, 2007
No light, no run, no fan. But have timer , and clock time
Check the interlock switch. Something must be stuck inside.
Jan 09, 2014 | Welbilt MR95TW Microwave Oven
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
Hi we have a Whirlpool X2-20ES microwave oven How can I set the clock (day time)? Thanking in advance Sid
1. Press CLOCK
2. Press STOP
3. Press number keys with correct time (123 = 1:23)
4. Press CLOCK again
Jan 28, 2011 | Whirlpool Microwave Ovens
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
How to reset the clock
On most microwaves you simply press (Clock) then push in the time with the number pad, then you press start button.
This is how most will set, some models will also have am/pm options.
If all else fails then get the model number of your microwave and make/Brand and go to the manufactures website, for instance if its whirlpool type in www.whirlpool.com and go to the section for manuals and it usually will ask you for your model number.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 04, 2009 | Welbilt Microwave Ovens
How to set the time, and can i download a usermanual anywhere? Thanks
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again...should set.
I have not seen a manual on-line for your model...ut htere are many others...perhaps browsing thru a few might help you. If not...try going into a store and looking for that model...the management might copy if for you...I would. :-)
Apr 24, 2009 | Microwave Ovens
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
