My MIL has aGM Frigidaire Refridgerator. I belive a 1940s model. Model #: 54000426 MJ-7 "GM Frigidaire 45B99942" She is interested in selling the unit, but we havent been able to find info of a value. If anyone could tell me what it might be worth, that would be fantastic. Thanks so much!
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
SOURCE: How old is my refrigerator?
Here is a --->link<--- to download the manual for your unit.
this --->link<--- will allow you the ask Frigidaire what year the unit was manufactured.
hope this helps
clarkco
SOURCE: Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Thank you for your post, friend!
I understand you need assistance in replacing the bottom drawer on your Frigidaire refrigerator. Could you please provide me with your model number? You should be able to locate your serial tag (which lists the model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
