Question about Kenwood KAC-8103D Car Audio Amplifier
Amp light turning off and on
I have a rockford fosgate p3 sub with Kenwood KAC-8103D 300watts Mono Amplifier and i have it all hooked up right but when i turn my radio on the light on the amp goes on and off real fast and the sub makes a deep bass sound real fast to but no music out of it how do i fix it
  • 2 more comments
  • pritchardgra Dec 25, 2008
    dude yea my amp turns on and off and makes a thud then cuts off kinda like a heart beat its very annoying i need help
  • Anonymous Jan 11, 2009
    Yeah i accidentally touched the positive and negative output wires together and now i get this heartbeat sound. first its fast.. then slowly like if someone is dying.
  • Anonymous Mar 29, 2009
    amp light turning on and off and when i hook up my speakers it makes a deep base sound
  • Anonymous May 06, 2009
    heartbeat thing. i believe it is in safety mode.. is there any way to get it out?
  • 27 Answers
If you see that happen you might need to your i c sound chip or your trasistor change then and check
Posted on Dec 11, 2008
I have two 12 rockford fosgates p3 hooked up to and 350.2 kicker amp i just got them so i hooked them up and my amp will keep turning on and off
How may ohms are the p3's and how are they hooked up? Some amps won't handle less than 4 ohms bridged. Try running one sub to each amp channel.
Also check power and ground connections.
Useing too small of wire for power, ground can cause the same problem.
Apr 17, 2010 | Kicker ZX1500.1 Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
2 12 p3d212 2 ohm hooking up to a rockford fosgate p325 .1 mono amplifier can it work? and how?
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
My kenwood kac-929 1000w amplifier is not powering my sub
unless you are a technician do not mess with the amplifier.
it takes years of school to learn electronics. unless it is a blown fuse or something simple,you will never fix it.
i did kenwood warranty for 8 years and the amplifiers are difficult to repair.
Aug 19, 2009 | Visonik V117SX Car Audio Amplifier
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood KAC-8103D Car Audio Amplifier Logo
259 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
