Question about Elmo Projectors HV-8000SX Slide Projector
My ELMO video presenter is not working. When I connect it to the video projector via s-video cable, it no longer shows an image, but the projector recognizes there is a signal. It recently fell off of a cart, but only a 4" drop. Can you tell me where I can take it for repair?
  • 2,237 Answers
You'll have to check the elmo usa website. you can either send it to elmo themselves, or to one of their authorized service centers (website). if the camera itself is damaged, it's pretty expensive. it may just be the s-video socket.
Posted on Aug 10, 2009
I open image mate and the laptop says that no document camera is connected. I have changed the cords and laptop still does not read the camera. The elmo will still project an image on the projector so...
I had the same problem with a TT-12 model. Dave from ELMO provided the resolution:
1. unplug the usb cable from your PC
2. on the ELMO:
a. Press MENU > PREFERENCES > USB MODE
b. ensure that APPLICATION is selected
c. exit the MENU and reconnect the USB cable to your PC
Oct 09, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
Chords needed for elmo 400af
You are a teacher, and you don't know the difference between a chord and a cord ? Amazing. I think anyway you mean a lead - the one you require has a plug on one end to fit the projector, and a plug on the other to fit the camera. Look in the respective manuals.
Jul 17, 2017 | Elmo Projectors Elmo Ev-400 Af Video...
yes, but i dont even have a cord yet. what cord should i buy?
Sep 22, 2012 | Elmo Projectors Elmo Ev-400 Af Video...
InFocus IN2102EP Projector My projector is connected to an Elmo TT-02s digital presenter that I use to show documents to my Students. When I first power on both devices, they seem to be working fine then...
Most projectors have an auto search function which can be switched off. You can then set the source to the specific input that you are using. Of the problem persists it may be the battery of the Elmo. (If it has one) Maybe it isn't strong enough to send the signal and maintain it.
Good luck.
Aug 05, 2011 | InFocus IN2102EP Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
How do I get the ELMO to display in color?
Elmo TT-02rx is a color document camera so it should work that way all the time. If it is not operating in full color, then you have a connectivity issue, a display issue or possible an issue with the camera itself. Are you connecting to a projector or a monitor? Or are you connecting via the USB cable?
Feel free to email me at fkemmer@shopvsc.com if you want direct assistance.
Frank Kemmer
www.shopvsc.com
Nov 15, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
I bouht an old Elmo but the lens seems to be missing. How does this projector project anyway What sort of lens system? Thanks to whoever answers
The TRV-35 series are not slide projectors in the normal sense. There isn't a projection lens to enable an image to be projected on a wall or cine screen. The unit is a digital convertor for producing an image via a TV or PC.
Aug 11, 2010 | Elmo Projectors TRV-35H Slide Projector
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
Need software
Try Windows Vista it sounds very powerful.
Mar 08, 2008 | Elmo Projectors TRV-35H Slide Projector
Elmo Projectors HV-8000SX Slide Projector Logo
286 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
