Question about SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive
PROBLEM IN PEN DRIVE
I HAVE I G B CRUZER PEN DRIVE .
WHILE INSERTING PEN DRIVE IN PC ,THERE ARE TWO REMOVABLE DRIVE SHOEN IN COMPUTER AND THERE AFTER MESSAGE SHOWN THAT I / O ERROR WHAT TO DO ?
  • 62 Answers
"limitation is that flash memory has a finite number of erase-write cycles. Most commercially available flash products are guaranteed to withstand around 100,000 write-erase-cycles, before the wear begins to deteriorate the integrity of the storage"
This means that your flash card may have been damaged by not removing correctly Flash card are not that reliable AS previous pen drives
Posted on Jan 22, 2009
I cnt open my pen drive..it's showing insert disk..it is a cruzer blade 16gb pen drive..and I have a windows XP..
Windows XP should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 09, 2012 | SanDisk 8gb X2 = 16gb Cruzer Blade Usb...
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Win 7 does not recognize pen drive
From the SanDisk website it says Win2000 and WinXP certified. It says nothing about Win7. try it in a different pc with Xp and see if it works. If it does then it is not compatible with Win7
Apr 04, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
What is Pen Drive? can so guide me how to prepair user manual for a pen drive with illustrations
download the driver if needed ,
if your using Win XP when you
plug your pen drive it should auto
config and you should be able
to click on " My comp" icon
and your pen drive will be labled
removable media drive e or f
Jun 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk pen drive cruzer 2gb not detected by the computer
first insert your sandisk pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My 1GB pen drive is not decteTING
TRY INSERTING PEN DRIVE WITH SHIFT KEY PRESSED...AND USE USB 2.0 (WIN XP)
Mar 31, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk cruzer micro 4 GB freezes computer. Running XP
dont open the drive after u putting into the system right click on the pen drive and scan the pen drive with your antivirus otherwise put in another system and check
Mar 24, 2008 | Computers & Internet
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive Logo
120 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
