Question about Goodman GMS90703BXA Heater
Pilot light not staying lit we installed a new thermastat
My husband says it looks like thres oil in the pan upstairs under the broiler can you help we have 5 kids and i dont want him messing with it if that sounds like a big problem to get the pilot light lit
  • Goodman Master
  • 3,239 Answers
Is this a propane gas heater ?
Posted on Dec 11, 2008
  • Paul Carew Dec 11, 2008
    if this is a propane heater then the oil is mercapton from the gas line , if so get a gas company to fix it , not really a job for your husdand (gas fitter for 30 years )
    hope this helps
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Hello, I have a cecilware fryer that looks exactly the same as the FMB 40 model.I don't know the model # because all info has been previously scratched off the label.The pilot light won't stay lit to light...
PLEASE DO NOT TRY TO FIX THE PROBLEM YOURSELF. You should hire an authorized service company to evaluate and fix the fryer.
Cecilware had a well known problem with their thermopile F178A. There was a recall on it last year. There are a few that are still in the field. It's possible your fryer might have one installed in it.
Their website doesn't have the manual posted. You will need to call them. 800-695-4500
Good luck
Apr 13, 2011 | Cecilware FMP40 Deep Fryer
The oven will not work, stove top works fine
Try starting the oven...open the broiler door and look to the rear of the broiler..you should see a reddish glow occurring...if not, then the igniter may have become defective...if it is a standing pilot stove then you need to make sure pilot is lit...if it won't stay lit, then the thermocouple may be defective..either way, these components are available at appliance parts store's or on the i-net
Dec 21, 2010 | Whirlpool Kitchen Ranges
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
Dec 19, 2010 | Magic Chef 31100 Gas Kitchen Range
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
HOW DO I LIGHT THE PILOT LIGHT FOR THE OVEN?
First pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit. Now if it doesn't light, sometimes you can just move this a little bit and get a little bit gas flow through there and in this case, it did light properly. And then now test the oven. Push in on the valve and turn it.
Kindly rate my help+++ Thank you
May 09, 2010 | Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My husband and I recently purchased a house that has a Comfort Glow Vent-free Propane/LP gas compact fireplace 14,000 to 26,000 BTU/Hr with Thermostat. Model CGCFTP We need to light the pilot light and it...
    Remove the small copper colores tubing going from the gas valve to the pilot assembly. Take it to a good hardware store that sells heaters and ask them for a new one.It is called a thermocouple.
    Nov 18, 2009 | Desa International Heating & Cooling
    Pilot light won't stay lit when you try to turn control knob to thermastat. Is it the thermocoupler, the control valve or the pilot assembly?
    Once your pilot is lit the thermocouple sends millivolts to the gas valve to tell it that the pilot is lit and to allow the gas valve to open. Check to see if your thermocouple is in the pilot flame. I f it is then you will need to replace the thermocouple.
    John
    Oct 03, 2009 | Heating & Cooling
    Goodman GMS90703BXA Heater Logo
    47 people viewed this question
    Top Goodman Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Tim Whalen
    Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
