Question about Harman Kardon DPR 1005 Receiver
Dpr-1005 problem my dpr-1005 alway shut down itselfs like 3 sec. after i tune on. please help...... thankssss
4 Suggested Answers
SOURCE: Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
Posted on May 13, 2009
  • 5603 Answers
SOURCE: intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Posted on Feb 16, 2010
Testimonial: "I had a CD player sitting on top of the vents... I took it off, blew out some dust and it seems to be working fine now. Thanks for the solution!"
SOURCE: My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Posted on May 31, 2011
HK DPR 2005 is shutting off by itself after running for about 5 seconds
when you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Apr 13, 2014 | Harman Kardon DPR 2005 Receiver
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Intermittent crackling sounds DPR 1005
Feb 16, 2010 | Harman Kardon DPR 1005 Receiver
Reciever shuts down by itself
Hi, i have similar/same problem, on initial power on, you have after 3 -4 secs an audible click from inside and all is good... if you then try to change inputs either via front panel and or remote, the unit switches off. if you change input prior to audible click, ie within 2-3 secs of power on , all is good and amp works fine, until you change input etc...very painful fault.. i thought it is sensing /checking the speaker outputs and detecting short etc ,so powering off to protect.. but then just my thought, i suspect something else, if anyone has the fix and can repair , please let me know.
Dec 24, 2009 | Yamaha RX-V800 Receiver
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
May 13, 2009 | Harman Kardon DPR 1005 Receiver
Can't get ps3 unit to stay on
WELL TRY UNPLUGING IT THEN REPLUG THEN TURN ON
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
My harmon kardon dpr 2005 shuts off after about 15 minute
Unit may be overheating. Make sure unit has good ventilation or that it is not being overdriven
Apr 21, 2008 | Audio Players & Recorders
Power shuts off after 2 or 3 sec.
please remove all speaker from receiver-volume down and test if the receiver shut down it needs to fix in service center-if not insert speaker one by one until you find the bad one-change its cable first and then change speaker itself.
Nov 29, 2007 | Marantz SR-5200 Receiver
Harman Kardon DPR 1005 Receiver Logo
79 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
