Question about Casio G-Shock GW500A-1V Wrist Watch
Watchband replacements? What is the best place to find a replacement band for the Casio GW500A? Thanks!
  • Anonymous Mar 26, 2009
    The Band is removed using a small jewler's standard screw driver .
    Problem Solver:
  • 5 Answers
On ebay you will be able to find the correct Casio band for your watch. There are 2 or 3 dealers that sell them but a little advice....don't buy the cheap ones! Buy ONLY the Casio replacement band and it will fit perfectly. You will need the spring bar tool to remove the pins that hold the band to the case. Don't try to install or remove the band without one....it will gouge the case at the pin stems and you will not be happy. They are cheap and worth every penny. Casio.com can also direct you to their watch bands. Hope this helps you and good luck!
Posted on Jan 07, 2009
    New Friend:
  • 10 Answers
If you have bought so you need to go to a service center or if you got any problem under 1month so you can call where you bought a watch. Top Seller of Week 10 Discounted Watches 24 7
Posted on Mar 29, 2015
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
Replacement band
You may try looking on ebay for the wristband.
Thank you,
Marcelo
Oct 23, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Replace band
Go to a watch repair shop they'll have lots of watchbands for sale.
Jun 18, 2013 | Casio G-Shock GW500A-1V Wrist Watch
How to change watchband Casio WVA106HA watch
Hi I have a WVA 106HA, the band has broken and I am looking fdor a band can you assist me
Jun 18, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
WHERE CAN I BUY A BAND FOR THIS WATCH GW500A
On Amazon.com. Search for
Casio Factory G-Shock GW-500
Dec 20, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I have an new band for the G-shock 500A but can't figure how to get the screws out of the old band to replace it. The screws turn both ways and don't seem to move. Is there some trick or special tool I...
Yes, You need two screwdrivers. One for each side. One screw on one side is long and goes all the way through the watchband and threads into the screw oon the other side which is smaller. Once you have backed the longer screw all the way out, you should be able to give the watch band a few light taps and the long screw should fall out. The screw on the aother side may require a bit more tapping or coaxing with the screwdriver to remove it. Once both screws are out, you can remove the watchband.
Sep 22, 2009 | Casio G-Shock GW500A-1V Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Casio G plastc watch case holder replacement source.
    i need a replacement case for g shock gw-002e,any ides where i can get 1.im in essex,uk
    Feb 25, 2009 | Casio G-Shock GW500A-1V Wrist Watch
    Change casio g shock resin watch band
    It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
    make sure you keep all original parts in case of toruble
    Post a photo if you can after the change will be nice to see the change
    Tom
    Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Casio G-Shock GW500A-1V Wrist Watch Logo
    747 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
