Question about HP LaserJet 3050 All-In-One Printer
52 scanner error
When i was print the 52 scanner error comes how can i fix it
meenubala
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
if the above step does not resolve the issue, please repair/replace the machine
Nikhil Gedam
Posted on Dec 22, 2008
HP LASERJET M1132 52.0 SCANNER Error how to fix it
a 52 scanner error indicates that the laser scanner that writes the image to the page is bad and will require replacement.
Oct 13, 2014 | HP Office Equipment & Supplies
Hp leserjet pro 400 scner error 52
The printing scanner (laser) has likely failed. HP has had some issues with the series of products and bad laser scanners so you may want to contact their customer service to see if you can get it fixed under warranty.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
When I initiate a print job on my HP P3005 laser printer it makes a roaring sound and then I get a error 52. I have read its the fuser and then I read its the laser scanner. Which one is it? Tom
Error 50.x related to fuser &52 for laser scanner assm.
For tec guys only: Open laser scanner assembly, remove laser scanner motor rotor, lubricate the shaft fix it back. (dont do this job with bare hands) check best of luck
Sep 21, 2011 | HP LaserJet P3005 Printer
52 scanner error. Turn off thenb on
52 is an internal scanner hardware error.
Unplug printer, wait 30 seconds, plug it in and power up.
Problem still there...make sure printer is plugged into wall outlet, not surge protector.
If error persists you will have to get the laser/scanner assembly replaced.
We arn't talking about the scanner/copier assembly at the top of the printer. This is the internal laser/scanner that is used for all your printing.
Jan 12, 2011 | HP LaserJet 3050 All-In-One Printer
Error 52.00 Printer says cartridge installed. Looks all ready. Starts making a noice as if to print then stop within 1 second. Nothing shows on the print queue
52 error is a bad laser scanner. The scanner needs to be replaced. No other way to fix the problem. If you want an idea of cost call us at 262-993-1551.
Sep 02, 2010 | HP LaserJet 2300 Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Hi my HP LaserJet 2420 Printer says error 52
Hi
I found this about your error.
Problem: When a print job is sent, paper doesn't pick up and a 52 error is displayed on the LCD panel.
Cause: The scanner motor is not spinning up to the correct speed. This problem can only be fixed by replacing the scanner motor.
Solution: Replace the necessary parts, all of which are included in this repair kit (along with easy to follow directions).
Kit Includes:
  • Scanner Motor
  • Instructional Video (CD-ROM or VHS)
Hope you can fix it All Best: Pineworks
Feb 03, 2010 | HP LaserJet 2420 Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
52 error problem
You can try following .....
An easy fix is to close the toner door completely. If this door is not completely closed, the printer will not allow the laser shutter to operate, thus giving this error.
Other items that U can fix themselves are to re-attach the black connecting link to the Toner Door Hinge.
If the inner door has popped out, you can snap that back into place
Dec 11, 2008 | HP LaserJet 3050 All-In-One Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
200 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
