Question about Dell Inspiron 630M Notebook
My entire c drive is currupt and i want to remove it but where would it be on an inspiron 630 m
    President:
  • 2,110 Answers
You need a booable OS CD and drivers for ur laptop...then boot from CD U will format the C: from the wizard...
Posted on Dec 11, 2008
Dell inspiron 1545 cd drive won't open when I hit eject, and then the laptop freezes
try using a pin small enough to fit into the tiny hole right beside your eject button, if there is a disc inside, this will help remove it and probably fix the fact that the drive is not opening. If not, you might want to completely remove it and check to see that your entire eject mechanism is working fine...
I hope this was informative enough
Nov 21, 2010 | Dell Inspiron 1545 Notebook
Drive not recognized driver missing or currupt
a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 30, 2010 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
My inspiron won't power up. Only green light on back and amber light on motherboard work. Have replaced motherboard and power supply box. Also checked and cleaned ram. Any other ideas?
There are a few things you can try. I've had similar problems like yours and went through the whole tower but it ended up being a currupt drive. You say that it won't power up, but is the fan on and the hard disc spinning. If they are you may find you have a corrupt hard drive.
What I did was remove the hard drive, connected to another pc via a adapter cable and opened it up from my computer. I backed up what i needed and then formatted the drive. Then returned it the tower and rebooted and reinstalled the operating system. It has been running fine ever since.
There are others that will recommend different ways, but to me it was easier and i lost no data and my pc is like a new one.
Sep 15, 2010 | Dell Inspiron 518 Desktop Computer
Dell inspiron 1705, Screen Blank, Hard drive working
hi
there 2 problem
1 is windows currupt
2 is Disply problem
Jun 01, 2010 | Dell Inspiron E1705 Notebook
How format my currupted memory card
connect the memory card on the PC with the help of Card Reader. Go to My computer, inside you will see the Removal Disk you have connected. Right click and choose format. If it gives you an error then there is a problem with the memory card.
May 06, 2010 | Dell Inspiron 6400 Notebook
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the underside to undo to find it.
The battery is on the motherboard. The entire bottom cover needs to be removed. Most of the laptop needs to be dissambled.
Nov 25, 2009 | Dell Inspiron 8000, Inspiron 8100 and...
Save/load problem on ps3
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 13, 2009 | Sony PlayStation 3 40GB System
My dell inspiron 630 has three lights. One power
Thye HDD can be either orange or green and will flash when the HDD is accessed
Sep 05, 2009 | Dell Inspiron 630M Notebook
File system error is showing on screen of my mp3 player. transcend mp3 T.sonic 630/1GB
connect it to pc....
format the disk entirely.
now load songs again.
this should solve the prob.
Mar 15, 2009 | Transcend T SONIC 630 MP3 Player
Dell inspiron e1505 not booting up(currupt hard drive). Did system test and getting serveral errors for hard drive test fail. error ofoo:1a44,065d,0244, Thanks, Rob
You have two options, try to back up your data and reinstall windows is that hard disk or buy a new disk, install it windows and use the old disk as second HD, just to store data.
Aug 13, 2008 | Computers & Internet
Dell Inspiron 630M Notebook Logo
55 people viewed this question
Alun Cox
