Maytag Serial #2256KQ3 - Freezer light will not work. I have replaced the bulb, checked the switch and it is clear of ice. The bulb that I have replaced is still working as I tried it in a lamp. any suggestions? It is a bottom freezer.
SOURCE: Bottom of Maytag Freezer Ices Up
I just had the Maytag repair man out and he wanted to replace to parts after defrosting the freezer. Over $300. He did not have the parts with him. Soooo... I am now in the process of using a hair dryer, even tough it is 107 here today. Ice was totally covering the coils under the back panel in the freezer. Easy to take out. Just remove the shelves and you will see it. If you don't totally get all the ice out it will build up even faster. He claims this will give us 2 weeks or so while the parts on on order. I now have all the ice I can see removed, I just hope it is out of the tube above the coils. I have all my food, lots of good steaks, I want to put back in the freezer. The original problem seemed to be the refrigerator was not working but the freezer seemed to be. Well, it just faked me out because it was just a fan or ?? I heard in the freezer. Wish me luck...MJ
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
SOURCE: ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
