Question about Frigidaire Dryers
Broken Spring/Shock for my GLEQ642AS0 Fridigaire Dryer
I am trying to find a replacement spring/shock for my dryer but I don't the part number. This spring is the one that is hooking onto the dryer drum to the frame. There are I think 4 on top and 4 on bottom suspending the dryer drum to the frame of the dryer. The spring is about 8 inches long and 3/4" in diameter made of heavy gauge steel. I substituted it with a spring of the same size from Home Depot (not made for dryers) but it only lasted a year. I would rather get an OEM part so that it won't break so quickly. Any idea what the part number is and where to buy one? Thanks in advance.
Carlos
    President:
  • Frigidaire Master
  • 2,651 Answers
There are no "suspension shocks/springs" on a dryer, those are usually on your washer. here is hte par number for he washer spring 134144700(which is about 8 inches long and 3/4" in diameter made of heavy gauge steel) youll need (2) and heres the suspension shock absorber number 134564200 its a set of 2, there shold only be 2 on your machine.
Posted on Dec 11, 2008
How do i change shock absorbere
Washer suspension systems can be fairly simple or quite complex and sometimes there is a failure due to the metal the suspension hooks or bolts onto has suffered fatigue and broken - sometimes a welding job is needed.
I have limited experience but the machines I have seen the main spring/shock units are accessible from underneath and it is necessary to turn the machine upside down (or lift it and work underneath).
The upper units (springs) are accessible from the top after removing the top cover.
Apr 16, 2016 | Washing Machines
Replace Belt
  • Unplug the dryer from the electrical outlet to prevent accidental shock which could result in death.
  • Locate the two screws on the bottom base of the front of the dryer by tilting the dryer unit slightly up and unscrew the screws on both the right and left side of the dryer, and put the screws to the side. Some units will have spring clips on each the right and left side. Insert a putty knife and press back against the spring clip releasing it from its hole.
  • Pull the bottom panel off and set it to the side.
  • please comment on this on how it work and rate
  • Dec 20, 2010 | Crosley CDE6000 Electric Dryer
    I HAVE A WHIRLPOOL DUET SPORT DRYER I MOVED IT TO PUT ON NEW DUCT AND NOW THE DRUM IS HITING THE INSIDE OF CABINET HOW DO I FIX THIS?
    Check the Vibration damper rods to be sure that...
    1. They are there and mount is solid.
    2. If they are broken in 1/2.
    3. The plastic knuckle mounts are not missing/broken.
    4. There is oil in the shock absorber/spring section of the rods.
    Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
    Replace/repair as necessary.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 21, 2010 | Whirlpool ET8CHEXSQ Dryer
    When stackable washer is in spin cycle it bangs on side of unit i checked under and all three spring legs are in place and working
    IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
    Sep 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Stackable washer and dryer. The washing machine tub is tilted to one side.
    Jun 30, 2009 | Kenmore Washing Machines
    Kenmore stacked washer and dryer was washer spins but out of balance
    Apr 21, 2009 | Kenmore 94802 Front Load Stacked Washer /...
    Washer
    Mar 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Washer drum tilted
    if possible change all three ..probaby right rear but others may now be stretched
    Apr 21, 2008 | GE WSM2420T Top Load Stacked Washer /...
    Excessive noise
    I had the same problem. Two things were bad. One was the shock absorber and must be changed out as a pair. Also one of the springs that supports the tub was broken. My guess is that the spring broke and the shock failed shortly after. since it was more easily accessible and appeared to be the problem, I replaced the broken shock. Only to find the spring was broken too. After replacing the spring, its worked fine for a couple of years. Obviously I'm looking at this site because I'm having another problem, but this time I think it is the tub bearing.
    Nov 05, 2007 | GE WSXH208A Front Load Washer
    Washer dryer error code 'check outlet pipe'
    the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
    Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
    Dryers Logo
    74 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
