Question about Dryers
Noisy dryer , rough sound sometimes knocking
Maytag commercial dryer. how do you get it apart. Normally I know how to start taking something apart. but this is confusing. I suppose because it is a commercial one. I searched the internet and couldnt find a repair manual for it?
Even here when I entered the model number it kept asking me to pick a valid model number so I had to take it off and enter it here.. MDE10CSACW Thanks for your help
Vern
  • 3 more comments
  • vpolzin Dec 11, 2008
    Does the top just snap on? It seems awful tight.'
    Thanks for the reply..
  • vpolzin Jan 02, 2009
    I appreciate the help , however I have not been able to get the cabinet open, any ideas.???
    Has anyone ever worked on this dryer or have a repair manual. I cant get it apart. I took the two nuts off from under the coin box, but dont' see anyway to get the cabinet apart? Help...
  • vpolzin Jan 08, 2009
    Does that felt pad on both ends of the drum, ever need replacing?
  • vpolzin Jan 09, 2009
    OK , here is the answer. You take out two phillip scres on the bottom front and then raise the front out at a 45 degrees and the two spring tabs on the top release, Be careful of the door safty wires. My problem was a bad blower wheel, it was out of round and loose on the shaft. Thanks for your help. Vern
    Problem Solver:
  • 16 Answers
Start by pulling up the top more than likely it is the drive wheel or possibly the belt has come loose but there is a spring on the drive belt tension arm that gets worn or the plastic wheel that rides on the drum that needs replacing
Posted on Dec 11, 2008
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
Brand new dryer is working but noisy
Aha: slope front dryer. Could very well be something down in the blower housing making the noise. To get into these you remove the door then the front panel comes off then the top can be raised so that you can get the front shroud off there to get the drum out. You cannot work from the back of this dryer. I have an older slopefront dryer service manual
Oct 26, 2011 | Maytag MDE21PN Electric Commercial Dryer
I have a Maytag MED5770TQ Electric Dryer. The drum is getting noisier and noisier and sounds like it will break if we run it again.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 22, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Not heating, in days prior and now the dryer became noisy, as if drum was rubbing something
heatman101
Jun 29, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas dryer, early model, tumble extremely noisy and loud. Any quick solutions?
Sounds as if blower wheel may be bad. Is it a rough sound.
Jan 31, 2010 | Dryers
Washer dryer comb. Washer is noisy in spin cycle, sounds like a bearing surface is starting to wear. Any normal wear parts that would do this or do I need to take the machine apart and look into it?
You have answered your own question. Any noise not normally there needs thorough investigation to find the cause. All parts wear normally. If you can fix anything without taking it apart........I cannot help you!
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
231 people viewed this question
Top Dryers Experts
