Question about NEC Mitsubishi Diamond Plus 92 19" CRT Monitor
Monitor keeps switching off
I have a Mitsubishi diamond plus 92 monitor and recently it has begun to switch itself to powere save go blank with the powere light going orange while the computer is booting up. It has once done this while i was working too. Rebooting normally gets it going again though sometimes from a cold start up this will need to be done 3 times before the screen stays on any ideas
  • Paul Gill Mar 24, 2007
    I was very pleased with the speed of response
  • Anonymous Dec 13, 2008
    i have 8 year old mitsubishi diamond plus 92 monitor, it works ok for 10 min but then it goes light purple colour to dark purple colour and then goes blank, reboot again does not work, start nest day, same above promble, advice please.
    President:
  • 2,961 Answers
The graphics card or onboard graphics driver may not be kicking in at boot up causing the monitor to shut down, check the graphics card connector for bent pins and both connector ends. If you are able, think back to when this started and use system restore to a date before is started. Also you may have inadvertantly updated your graphics driver with one of windows generic drivers, of which may be the cause. You can also try pressing F8 on boot up and selecting 'last known good configuration' and see if that cures it.
Posted on Mar 18, 2007
SOURCE:
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My monitor is switching off in an unexpected manner and I suppose that there is a defect with the main power supply switch
First thing please check powercode is proper attached or not with monitor and power supply side
second thing is that due to bad power cable that its happen so please change power cable
May 20, 2010 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Power button won't latch on. Monitor powers up if button kept depressed.
Replace the  power switch. If you can't find a replacement part open the case and solder the connections of the switch so they will be permanently on. You can place a new switch on the power cable.
Nov 26, 2009 | Mitsubishi Diamond Plus 91 19"
Monitor Does Not turn On...
My Friend you have a problem in the power supply, you try voltage check, check if you have output in the b+. if nothing, there is a regulator in power section, for example ic401, you look at the board you will see all the components section of ic401, all the capacitor have 4 for example c423 or resistor r423 like that one. You check all the section of the power supply. Hope I help you. bye
Mar 20, 2009 | Apple Mitsubishi Diamond Pro 2060u 22" CRT...
Screen goes to single horizontal line across middle, sometimes momentarily at first, then resets after being switched off for a period of time (can take minutes, hours or even days) Model: NEC Mitsubishi...
  • Complete service manual with an error search tree , sometimes there is a vertical ic defect by deformed capacitors hanging around that or a powerline from powersupply failed (sometimes there could be a defect fuse resistor to find ) or only a bad factory cold soldering by manipulate some passive components somewhere in vertical stage .
Mitsubishi Diamond Plus 93SB Service Manual
May 06, 2017 | NEC Mitsubishi Diamond Plus 93SB 19" CRT...
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
Color temperature for the monitor
I have mine on 9300K. The whites seem whiter to me rather than the yellowy tint at lower temps.
Nov 12, 2008 | Mitsubishi Diamond Plus 91 19"
Now the monitor flickers..
Your monitor is slowly dying. Get ready for the eventuality and start saving some bucks for replacement.
Sep 18, 2017 | Mitsubishi Diamond Pro 91TXM 21" CRT...
NEC Mitsubishi Diamond Plus 92 19" CRT Monitor Logo
163 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
