Question about VIA JetWay PM9MS Socket 478 PM800 Micro ATX Intel Motherboard (MBJ9MS)
Trying to install wd 160gb sata drive on xp home sp2
I have a mach speed pm9ms mb, trying to install wd 160gb sata drive, made a viasatadriver disk intallation disk from my driver software and press f 6 when xp ask for third party drivers.I end up with txtsetup.oem cannot be found.I have enabled the sata in my bios,but still ng. Thanks for any help......Tim Jetway PM8MS Mob, trying to add a 640 WD 7200RPM 16MB cache SATA HD, POST or the RAID util. not showing the HD. SATA getting power, I can feel and hear the HD moving. Cables a in correctly.
    Scholar:
  • 176 Answers
Try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Posted on Dec 11, 2008
Lost magic install cd for my pm9ms/pm9m motherboard. On board sound and network don't work.
dear open this link ......
http://www.jetway.com.tw/evisn/download/bios/index-1.htm
Aug 26, 2009 | Mach Speed (PM9MS) Motherboard
Adding a secondary SATA Drive
You need to update the bios, in order to support 160GB. Check the manufacturer and model. Go to website and download the latest bios.
Jul 24, 2009 | MSI PT880 Neo FSR Motherboard
Sata hdd not Detect
To install Windows XP on SATA or advanced IDE hard drive, you will need to insert a driver diskette at the time of starting the installation process and pressing "F6". For more details visit the link below:
http://ufixitnow.blogspot.com/2009/04/oem-driver-support-during-windows-xp.html
Apr 09, 2009 | Microsoft Windows Xp Home Edition Sp2...
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
i think instead of enabling sata y dont u try enabling IDe
Nov 24, 2008 | Mach Speed (PM9MS) Motherboard
Driver for main board
Hi fady1973, It would have been a little easyer if you would have posted the manufacture of the board.
After looking at a few boards I believe you are looking for Jetway's PM9MS, Socket 478 PM800 & 8237 chipset. Click on this link: http://www.jetwaycomputer.com/spec/pm9ms.html
No driver's listed.
Mach Speed MB: http://www.machspeed.com/specs/discontinued.htm#p4m800
You can try VIA at this link: http://www.viaarena.com/default.aspx?PageID=420&OSID=7&CatID=1120
The PM800 is supported here. You can also allow VIA to scan you're board for the correct drivers. As a member of driverguide.com, there were no drivers found for either PM800 or PM9MS.
Sorry, unable to find drivers other than VIA.
Good Luck!
Mike
Jun 03, 2008 | Intel Motherboard
Mach MSNV-939 motherboard - RAID 0 - How to setup?
im in the same spot... di anyone found this sol. ?
Apr 10, 2008 | Mach Speed (MSNV-939) Motherboard
Boot difficulties Seagat Baracuda 7200, 300 GB
Could have something to do with the IDE being set to master.. It has been known that sometimes the SATA drive will take over as the master.. Try changing the IDE drive to cable select, and see if that helps.. If not, change the SATA to slave.
If that doesn't work, post your motherboard model# along with your bios name/version.. and we'll go from there.
As a side note: When they are connected the way they are now, does the bios show both drives?
Mar 28, 2008 | Seagate Barracuda 7200.8 300 GB Hard Drive
No HDD Found on initial XP Install
Did you insert the sata driver disks when prompted in the first stages of installation? I think it's mentioned as scsi drivers.
Mar 04, 2007 | Mach Speed (S755) Motherboard
VIA JetWay PM9MS Socket 478 PM800 Micro ATX Intel Motherboard (MBJ9MS) Logo
368 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
