Question about Maytag MDE16CS Electric Dryer
Maytag coin operated dryer
My dryer leaves the clothes damp after going through the cycle.I checked my vent pipe and it looks clear the whole way! can you please help?
  • ribbsey Jan 04, 2009
    we have a caravan park with a maytagmde16cs dryer . we are getting cmp[laints that after the time run , the clothes are still damp.jim
  • Anonymous Mar 15, 2014
    How do you set the dryer coin operated cost on a Maytag electric dryer Model MDE14PDACW?
  • 67 Answers
Is the dryer heating at all? have u tried it disconnected from the vent to see if it makes any difference, if disconnected and it still doesnt work correctly u'll probably need a new thermostat it also depends on if it gas or electric heating elements in electric are either good or bad no in between its just a coil
Posted on Mar 21, 2007
My DWJR-ELE-2406026-FM54 dryer is getting hot but not drying the clothes. Even after 3 cycles they are still damp, not warm at all. What would that be?
Ventilation, check the vent hose and the vent pipe and the damper outside for restrictions probably clogged with lint. If the moisture can’t escape the clothes won’t dry.
May 10, 2018 | Dryers
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
My Maytag Bravos XL electric dryer doesn't dry clothes. When I try to run a second cycle it seems like it's too hot and won't start again until it cools.
Make sure your vent pipe is clean and filter is clean. Air flow is number one reason for dryer failure, Check the whole inside of the dryer for lint build up and in the exhaust pipe. The dryer has to vent the humid air in order to dry the clothing. If it can't do that, it overheats and also the humidity stays inside the dryer.
Oct 27, 2013 | Maytag Dryers
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My daughters Maytag Atlantis electric dryer model# MDE7400AY has just warm heat, taking an hour to damp dry towels, and there is NO lint in trap. Checked to make sure exhaust pipe is not clogged, and found...
cleaning the vent is always a good thing, But check the outside vent cover, some of them have a flap inside that sometimes get clogged with lint especially if damp, The only way for moisture to leave a dryer is to have a clear shot for the heat to escape , thats all done through the vent, if it has moisture in it, something is blocking its escape
Jul 13, 2011 | Maytag Dryers
Clothes still damp after 2 cycles
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Kenmore 90 series dryer leaves clothes damp. The dryer gets hot, but after almost 2 hours a large load is still damp. Happens on both auto sensing & timed dry. Checked insides & all is clear -...
Sounds like a venting problem at the house pipe.
Make sure the house venting pipe is completely clean and vent hood just outside is free of any blockages.
If all that is cleaned I would check all working thermostats and high limit thermostat as well.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Maytag MDE16CS Electric Dryer Logo
328 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
