Question about Microsoft Windows XP Professional
How to enable registry editing
When i try to open reg edit its showing "Registry editing has been disabled by your administrator" can i solve this problem...can anyone help me
  • 2,110 Answers
Method 1 - Using Group Policy Editor If you are using an edition of Windows Vista (Windows Vista Business, Enterprise and Ultimate editions) which includes the Group Policy Editor, follow these steps:
  • Click Start, type gpedit.msc in the Search box, and press ENTER
  • Go to the following branch:
User Configuration | Administrative Templates | System
  • Double-click Prevent access to registry editing tools
  • Set it as Not Configured
Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
Method 2 This method should work in all editions of Windows Vista.
  • Download reg_enable.vbs attached at the end of this article, and save it to Desktop
  • Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  • Switch to your Desktop directory by typing the following command, and then pressing ENTER:
cd /d %userprofile%\desktop
  • Then, type the following command and press ENTER
wscript.exe reg_enable.vbs
  • Type EXIT to close the Command Prompt window.
If everything worked fine, the DisableRegistryTools policy should have been removed by now. See if you're able to launch Regedit.exe now.
Posted on Dec 11, 2008
Hii,, i hv made some folders hidden ..and now when i am trying to unhide i m not able to find folder options.. my operating system is vista home basic.. when i am typing regedit in search option it is...
Here are the some steps you can do to enable your folder option .
Type gpedit.msc in RUN dialog box and goto: User Configuration -> Administrative Templates -> System
in right-side pane, set "Prevent access to Registry editing tools" to either Not Configured or Disabled.
Type regedit in RUN dialog box and press Enter. it'll open Registry Editor, now go to following keys:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Current Version\Policies\Explorer
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Current Version\Policies\Explorer
In right-side pane, check whether a DWORD value named NoFolderOptions exists or not? If it exists, delete it.
2. If you don't want to do any registry editing and are not familiar with editing the registry, then you can simply download following file, extract it and then run the .REG file:
Jul 17, 2011 | Computers & Internet
How to Solve " Registry Editing has been disabled by your Administrator"
Methods to Remove the Registry Editing Restriction
Method 1 :- Using REG.EXE Console Tool
  • Click Start, Run and type this command
REG add HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem /v DisableRegistryTools /t REG_DWORD /d 0 /f
You should be able to launch Tweak UI, as well as the Registry Editor.
Method 2 :- Using the Group Policy Editor (Windows XP Only)
  • Click Start, Run and type gpedit.msc and press Enter
  • Goto the following location User Configuration | Administrative Templates | System
  • Double-click Disable Registry editing tools and set it to Not Configured
  • Exit the Group Policy Editor
Note:- If the setting already reads Not Configured, set it to Enabled and click Apply . Then revert it back to Not Configured. This ensures that the DisableRegistryTools registry value is removed successfully.
on Jan 12, 2010 | Computers & Internet
How to activate task manager on my pc
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
Nov 12, 2010 | Computers & Internet
My windows vista dont have internet and sound
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors. Open Internet Explorer
  • Open the Tools menu
  • Select the Internet Options menu item
  • Open the Advanced tab
  • Check the box next to "Disable script debugging"
  • Remove the check next to "Display a notification about every script error"
  • Click the OK button
  • reset all setting, clean registry key for internet explorer use registry cleaner reg in out to scan ur error
Sep 07, 2010 | Microsoft Windows Vista Ultimate Edition
My task manager doesn't work anymore can u help me fix this?
Try this:
If Task Manager has been disabled, you can re-enable it if you have administrator privileges on the computer.
To enable Task Manager on a computer running Windows Vista Home Basic or Windows Vista Home Premium This procedure requires you to edit the registry. An incorrect change to your computer's registry could render your computer inoperable. We strongly recommend that you back up the registry before making any changes. For more information, see Back up the registry.
  1. Open the Registry Editor by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, typing regedit into the Search box, and then pressing ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Navigate to the following location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies
  3. Double-click System, double-click DisableTaskMgr, change Value data to 0, and then click OK.
To enable task Manager on a computer running other editions of Windows Vista
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, type gpedit.msc in the search box, and then press ENTER.
  2. Under User Configuration, double-click Administrative Templates.
  3. Double-click System, and then click Crtl+Alt+Del Options.
  4. Double-click Remove Task Manager, click Disabled, and then click OK.
or you're computer might be infected by a virus, if you're not the one who disabled the task manager.
Try to scan your computer also.
May 08, 2010 | Microsoft Windows XP Home Edition
I think my laptop has a virus because when i attempt to open run and type "regedit" a window will appear it say "registry editing is disable by your administrator" i am the administrator but i did not do...
to make sure you´re virus free try another antivirus.
Go to:
and run the online scanner ( works with Internet Explorer only, I think ). It is pretty accurate and might find something that Avast missed.
Oct 21, 2009 | Computers & Internet
Re.Launching Registry editor,To Cure CD-DVD-writer not Responding
Are you the Administrator, and do you have the Administrator's password?
If so, then log in as Administrator and make the necesary changes.
However, if not, then you must reinstall the OS, to establish yourself as such.
Apr 17, 2009 | ASUS DRW-1608P DVD±RW Dual Layer...
Can't edit registry on Vista 64 bit
Hi there. With Vista, even though you may have an administrator account, some actions require you to go through an "extra channel", so to speak. This is to add extra security to your system from outside interference.
What you should try:
Click on your Start Menu.
At the bottom, under All Programs, type regedit. Do NOT hit enter.
At the top, it should display the regedit program.
Right-click the regedit program and then select Run as Administrator.
It should now let you edit.
Let me know how it goes
Apr 16, 2009 | Microsoft Windows Vista Ultimate Edition
regedit - to disable this file from running, delete it. if you want to turn off the registry, boot computer into safe mode (tapping f8 key while booting). if you need to manually uninstall a program, do an F3 search in the registry for the program name as a search string. there can be as many as 500 registry entries for the program... if you adopt the f3, delete, enter, f3, delete, enter, you may be able to uninstall the program's registry entry in as little as 15 minute to 1 hour... best of luck, I am not responsible if you delete a wrong value and crash your computer .... heheheeheheh.
Sep 26, 2008 | Red Hat Enterprise Linux ES 3 Standard...
Microsoft Windows XP Professional Logo
292 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
