Apple iBook G3 Clamshell  Mac Notebook
Problem for Apple iBook G3 Clamshell (M2453B) Mac Notebook
Ibook has gone nuts
By pazuzu12 on Dec 11, 2008
First off here is the deal, I've had my 3g apple ibook for 5 years, I bought it off a friend, Like I said I've had it 5 years, it is a little older than that, however, when I 1st got it, it was running on OS9, I have to admit I had no dealings with macintosh and had only ever used windows. As I was initially using the ibook I kept recieving msgs about not being able to use certain software with OS9 and would need to upgrade to OSX, 2 cut a long story short somewhat, I managed to get OSX and went to put it on the ibook, I was asked did I want 2 delete some stuff off the main drive to make way for OSX, not being familiar with OS9 I pressed yes, much 2 my confusion as the whole ibook wiped, not 2 work again for another 5 years. so present day, Began fumbling about with the ibook, and to my suprise began to make some success with it, as it happened, I had all the relevant discs and managed to reinstall OS9 back on to the drive, so the ibook looked basic I even managed to get it online, via ethenet broadband at a friends house, did some software updates and that was that, so began 2 weeks of absolute hell, I've not been able to get the sod online at my own home, again via ethernet broadband and have currently reinstalled OS9, OS9.2, OS9.2.2 and OSX something like 20 times. Finally, I managed to get all mof it reinstalled, and eventually OSX on the ibook, but still I can't get it online, I've trolled all over the net and can't think of anything that might help, I've followed most possible silutions.
PLease Help me, if I can give you any other info I will
Comments:
Dec 11, 2008
- actually, it's not an ibook clamshell, it's the white ibook notebook type
Dec 19, 2008
- HI Sean, thanks for replying, to be honest, I'm not totally sure what verson of OSX I have, I assumed until recently that there was only one type, actually, I also have to admit the OSX I have was a friends, so it never came with any documentation. I am wondering whether I've altered something to some settings as regard to the TCP/IP area, but like I mentioned in my initial request, when I finally managed to reinstall the OS9.1 disc on to the ibook I was at a friends and managed to get the ibook online, I did the software update button in the drop down, directly after that I tried to install OSX, it started gonig odd then, You know, like the upgrade initially didn't go all the way through it's install or as it appeared, but like I've said, I've re-installed, installed, re-installed OS9.1, 9.2, 9.2.2 and OSX what must be 50 times over the past 2-3 weeks. I've surfed the net looking for any answers I can find, a one step forward 3 steps back scenario. I've tried to download straight from the apple site then transfer on to the ibook, so, to answer your reply as far as I am aware I am now using version 10.0 .
To be honest, from what I've just typed out there I'm not sure I'm of any use what so ever, I'm ot a total dill, but I guess I've just used and gotten used to having to deal with windows for so long, granted, I am slowly learnig some small tips to using and getting to know macs and I actually see why people prefer them to windows, it's a shaem they are both screwing us over.
Well, I've babbled enough, if you can make sense of what I've said you are a king amongst kings, lol
Thanks Sean.
Pazuzu12
Clarification Request
Posted by seaniepie on Dec 16, 2008
Hi Pazuzu12,
I am sorry to hear of your Phun with your white iBook. Sounds like a nightmare! I'm pretty sure I can work you through this. Can you firstly confirm which version of OSX you have installed on it at the moment. This will help me give you the best intructions.
Cheers
Sean
PiDigital
Solution #1
posted on Dec 29, 2008
Not Rated)
cenobite
Rank: Guru
Rating: 86%, 76 votes
What version of OS X are you running Jaguar Panther or Tiger? How are you trying to connect to the internet? Through a router or directly connected to the DSL/Cable modem? There are some things that you need to look at to get the information you need in the System Preferences Network tab.
First look to see if it says you are connected via Ethernet and what colour the "light" is (green yellow or red). If it is green you are connected and have an IP address, yellow connected but there is an issue with the IP address and or connection and red means that the ethernet does not show any connection to the network.
Depending on what that shows, look at the interface tab (may have to select advanced) and see that the ETH0 is present and selected and that it is first on the list.
You then go to the TCPIP tab and check that it is set for DHCP or automatic configuration.. If it is then try to renew the DHCP lease. If it is set for anything other than that, change it apply and try again.
I had a G3 iBook that was probably about the same age and specs, and I noticed it really only started working well after I put Tiger 10.4 on it. 10.2 was not great and of course with 9.x it would not run new stuff.
Feel free to ask for more help if you need it. I have A LOT of experience with the machine you have running different versions of OS X.
Was this helpful?
Yes
No
Popular Solutions for Apple iBook G3 Clamshell Mac
Questions and Unsolved Problems for Apple iBook G3 Clamshell Mac
Do you recommend Apple iBook G3 Clamshell (M2453B) Mac Notebook?
Answer
Answer
cleaned the keyboard with the spray, and now my laptop does not work, is it possible that oksidirao... (More)
Answer
I had a cd stuck in my intell based macbook. I stuck in a piece of thick folded paper and just... (More)
Answer
can't install the wireless broadcom802.11n network adapter of Dell vostro 1700
Answer
After a few minutes of scanning the icons have pinkish shadows and after a few seconds the screen... (More)
Answer
my camcorder is not working the video recordings are fuzzy while recording or replaying. how can i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Mac Laptops Experts
Top Computer & Laptop Repairmen
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
