Question about Hitachi 60FX32B 60" Rear Projection Television
BLOWN RESISTORS Just like to know where I can purchase replacement resistors. The tv is Hitachi Model 60FX32B , the burnt out resistors are RK30,RK31 & RK29. Contacted Hitachi,but had no luck. Hope I can purchase these resistors myself,instead of repairman charging me 300.00 to fix it. No wonder nobody tries to have any electronics repaired anymore. Thank you for your time..
  • weirdal May 11, 2010
    Were the resistors burnt? That means they burnt out because too much current passed through them. Chances are if you just replace them w/o figuring out *why*, the new ones will also burn out. Unless you really understand everything in the aforementioned service manual, your chances of fixing it are slim. I've seen way too many sets that were FUBARed by somebody who thought they knew more than a tech with years of experience.
  • 905 Answers
You can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here http://www.eserviceinfo.com/downloadsm/12926/Hitachi_50FX30B.html
then to order resistors you can get them here http://www.nteinc.com/
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Posted on Dec 11, 2008
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
As stated in your response to another person (Hitachi 43UWX10B)
Your post didn't get attached to the message in which you read the 'fix' for your set so the person who helped, will likely never see it.
You might try re-entering your brand/model info and sort through the results to find the original message.
Oct 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43FDX Rear Projection TV
Yes, You will need to replace the 2 convergence IC's. Hitachi part # CZ01341. Generic part # STK394-160E These are the upgraded replacement parts. Also look for any burnt resistors near these IC's.
May 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Need to find manual.
need a manual for a HITACHI DZMV550A camcorder
May 18, 2009 | Sprint Hitachi P300 Cellular Phone
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Hitachi Rear Projection TV Flickers Red
No, this could mean a loose connection on crt board(red of course) Look also and check to see if lines going to board are connected correctly. If nothing, then there could be something trying to short itself out on crt board. look for burnt resistors and bad capacitors.
Jan 19, 2007 | Hitachi 51G500 51" Rear Projection...
Televison & Video Logo
178 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
