Question about AEG S72348KA ST STEEL Refrigerator
Tripped earth leakage, i made sure element in freezer was secure, had trouble once before, tried fridge again ,light came on but no sign of fridge kicking in.i just nned to know whether it is serious or an easy fix. Don't live close to repairers. Regards Evan We have the same problem with our AEG Santo 72348. Firstly a mouse(!) crawled up into the PC board and blew the whole thing. We struggled to find a repairer here in Australia and eventually shipped the parts in from South Africa. We found someone to repair the fridge for us but when we got it back the moment we plugged it in the tripped the earth leakage on the house. The repairer cannot find the problem and his solution is to just "lay a new dedicated cable from the distribution board for the fridge". That's no solution for me. PLEASE has someone got any ideas?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, let's review the basics:
  • tripped earth leakage - is a protection system more sensitive that the standard breakers. It measure if the current coming in is equal to the current coming out of circuit. If not then it will assume that a small part of the current does not flow out the other wire but rather "leaks" to the ground/earth.
  • light came on...no sign of fridge kicking in - either the logic controller board is faulty or the compressor/starting capacitor (if used) is faulty.
The easiest way to test for an earth leakage fault in your refrigerator is to unplug the unit, use a DVM or VOM set to the highest resistance range of X100 and test both the prongs of the AC plug against the exposed metal part of the body of the refrigerator. In an ideal world, there should be none. Since the logic controller board may be using relays to switch on other components in the refrigerator, it might be to your advantage to do the same with the different wirings/components internal to the unit. Pls pay special focus on the compressor motor and the starting capacitor (if one is used), the transformer that supplies the power for the logic controller and all others.
The general idea is that none of the wirings in and out should have a resistance reading/connection to the body of the refrigerator or to be more exact, any metal part that the user can and may touch.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 734 Answers
First check wiring of your Refrigerator, may be there is problem of wiring.Also check that there is a power booster condenser on the Refrigerator back side is working properly or not.
    Genius:
  • 1,199 Answers
Itjust sounds like a stuck or broken switch& look on inside of door to see if stuck before you change it ..and no this is not going to affect the unit at all
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
Freezer working fine, fridge not cooling. Left to defrost last night, turned back on this morning and all seemed fine. Fridge was cooling and seemed to be running all ok. Tonight the earth leakage keeps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Fisher and Paykel E522BRX Bottom Freezer...
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Periodic tripping of earth leakage switch.
your not supposed to run an appliance on a ground fault circuit because most of the components ground to the body og unit do you have it on a gcfi well here in america anyway
Jan 01, 2008 | Refrigerators
AEG S72348KA ST STEEL Refrigerator Logo
51 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
ashburton
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
