Question about Proscan PS65000 65" Rear Projection Television
1080I Picture Not Aligned Properly (Color is FINE, not a convergence issue)
The picture is misaligned such that I can see the time-code info of the broadcast at the top of my screen and the picture at the way bottom of the incoming signal is cut off (too low to appear on the screen). It seems like all the guns are misaligned, but this does not occur when I feed it a standard 4:3 signal. The color alignment is fine. Is there a hidden way to adjust the overall picture alignment? I can't believe it's not a standard feature to be able to adjust this manually. Make: ProScan Model: PS65000 (I shouldn't have to specify this, but I see tons of people asking questions in this section that don't even have this make/model). Thanks so much, Alan
  • Alan Kaplan Mar 22, 2007
    Thanks but I can't get into the service mode. I tried what you suggested, but I get no P/V codes on-screen. To be sure I understand:
    1. Turn TV ON
    2. Hold Menu (on the set)
    3. Press & release Power (on the set)
    4. Press & release Vol+ (on the set)
    5. Release Menu
    When I hold menu, I get the standard menu. Then when I hit Power, I get another menu -- looks like an input guide of some sort. Then when I hit Vol+ and release Menu, the screen goes black for a second and the picture comes back. I tried it with the Component input (which has a signal) and with Vid1 (which doesn't have a signal).
    Any thoughts? Even though it didn't work for me, I'll still give a good rating for the solution as it's obviously a good one and something else is going on here...
    Hmm... I went to rate the solution after the post and now it says thanks for rating it, but I hadn't yet... Oh well, hope the site thinks I gave it a good rating, lol.
    President:
  • 3,130 Answers
So if the picture is short at the top and the bottom you can first try the service menu and adjust the vertical size and the vertical center. You must be very carefull when adjusting this service menu as a small mistake can make a minor adjusment become a very costly repair. Do not attempt this if you do not think you can figure it out and always always write down the values of the adjustment before you try them.Ok Heres goes. To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button. You will now have some information on the screen: "P0 V0" To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value. P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.Go here to get the chart as it will not fit in this post. You really should invest in a service manual as all the info you will need will be in this manual for your set. Good Luck.
Posted on Mar 18, 2007
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Convergence problems at 1080i resolution
With TV off ON Front Panel board Press and hold vol-&ch- at same time untill set comes back on you should now be in Service Menu ,try adjusting convergence then.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
Picture goes goofy in 1080i
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Proscan PS65000 65" Rear Projection Television Logo
172 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
