SOURCE: replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
SOURCE: Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
SOURCE: Where can I get a seal for the flow valve on a
www.arrowmotor.net and use the contact button. You would likely want the rebuild kit that includes all the gaskets and o-rings.
Be sure to include the model number off the valve, which should have SP at the beginning.
SOURCE: have a hayward s166t. lost top paper on the filter
If it is relatively new you should have a 71113T or 714T valve on top. This manual should answer your question. If not, please comment with how old the filter is.
John
SOURCE: my hayward s166t filter is
Go to the following site... http://www.haywardnet.com/inground/products/manuals.cfm#FiltersSand
Scroll down to the Valves under General Pool/Spa Equipment. Download each of the PDF Dcouments for Valves and find the one that closely matches your design. It will show the position of the different settings.
