Key came off of keyboard. How to replace on laptop Compaq 6715b model? Is there a tutorial on how to replace them?
  • 58 Answers
There is a great tutorial here, with photos. (This is not my site...just a helpful and very complete tuturial I found for you with Google)
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/all-comments/
Posted on Dec 11, 2008
Hp compaq 6715b charging problem
Good day .If i was in the your position i would carry the laptop to a repair shop and let them check it and maybe change the charging port of the laptop
Jan 14, 2014 | HP Compaq 6715b Notebook
Hp 6715b vga's to external display fine, but no internal display. Replaced display cable, inverter, and lcd is good, I know this as fact ! Still no display, HELP ?
Hi, First push your FN- and the F- button that has the display symbol it may be set to the external screen. Can you see anything on the screen if you hold a flashlight close to it? If so I would say your back light went out and will need to be replaced. If this is not the case, recheck your cable and make sure it is grounded properly.
Also check the sleep button, This should be located above the keyboard. Sometimes it gets stuck.
Robert
Oct 19, 2013 | HP Compaq 6715b Notebook
Power-on Password
b> If your HP Compaq 6715B laptop is lost or stolen, the power-on password can protect the valuable data on your computer. Even so, there may be times you'll want to clear that password and knowing the right procedure will make that easier. Once the power-on password is cleared, the Compaq 6715B will no longer require you to enter a password just to start up your laptop.
Shut down your Compaq 6715B and wait for it to power off. Press the "Power" button to restart the laptop. Tap the "F10" key after the Compaq splash screen appears. Wait for the setup menu to appear. Use the arrow keys to navigate to the "Security" menu and scroll down to the "Power On Password" option. Delete the entries in both boxes, then press the "F10" key. Choose the "Save Changes and Exit" option to exit the setup menu. Wait for the laptop to restart and verify that the laptop does not prompt for a power-on password. Hope this helps.
Dec 15, 2012 | HP Compaq 6715b Notebook
What function key gives entry to cmos
BIOS is fixed program that starts up the computer. BIOS is initialized during start up of HP Compaq-6715B which sets the computer settings to be uploaded. BIOS enables the creation of a bootable diskette, CD, or USB key that can be used to locally restore or upgrade the System BIOS in the supported notebook models with a 68YTT Family ROM. Only insert the USB drive that will be used to format and create bootable BIOS upgraded USB media. However, you should remove all unused USB drives and flash drives from the notebook before. In order to ROM family and ROM date, press F10 on the target notebook during startup to run the setup utility.
The tips to get into the BIOS of HP Compaq-6715b are:
  • Press F2 for setup
  • Shows logo
  • Independent of OS
Press F2 for setup
BIOS often has a blue background, and uses the arrow keys, PageUp, PageDown and enter keys to change the settings. After you have got into or accessed the BIOS, you can change the boot order settings so that the floppy disk is checked first to see if it contains a bootable program. Usually a message will appear telling you how to enter the BIOS setup program as the computer starts up, such as Press F2 for Setup.
Shows logo
Your HP Compaq-6715b might be configured to show your computer's logo instead of important BIOS messages. In this case, you can press Esc or Tab while the logo screen is visible. If you are facing problems pressing the pause button in time, turn on your computer with your keyboard unplugged. In this situation you will receive a keyboard error, which helps you in pausing the startup process long enough for you to see the keys necessary to enter BIOS.
Independent of OS
The PCs with both PS/2 and USB connections are configured to only allow USB input after the POST. If you are using a USB keyboard, it could be impossible to access BIOS. You would need to connect an older PS/2 keyboard to your PC to access BIOS. The BIOS accessing is independent of any Operating System on your computer because the BIOS is part of your motherboard hardware.
http://www.bostonrecycling.net/
Jun 25, 2012 | HP Compaq 6715b Notebook PC
Manual to replace display and touchpad on hp 6715b
Here's a direct link to this model's service guide:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01570696/c01570696.pdf
On page 76 of this service manual, the procedure to replace the display is illustrated.
As for the touchpad, it is attached to the laptop's top cover. The procedure to replace the laptop's top cover is illustrated on page 81.
Sep 23, 2010 | HP Compaq 6715b Notebook PC
Keyboard mmmmmmmmmmmmmmmm
Might be a sticky key situation.  If you have patience and a steady hand, you can fix this yourself.  But, you need to figure out if the problem is with just one key, or a couple.  Sometimes, removing the one key that causes the problem and putting it back on again will fix it.  I would type in your model computer in google and look for a tutorial.  Something like http://www.fonerbooks.com/laptop15.htm will help.  If all else fails, it is not too costly to replace the keyboard itself.  (Simple installation, too)
Mar 05, 2009 | HP Compaq nx6110 PC Laptop
Voltage HP 6715b
Look up the voltage acceptable for a HP  6715b laptop in the manual  that came with it. Go to Radio Shack and buy a $9.00 Grounded Adapter Plug. Be sure you take the HP power cord.
Feb 07, 2009 | HP Compaq 6715b Notebook
Keyboard
You want to replace that keyboard? If so, I suggest you take it out and look at the bottom to see what the part number is. If NOT, then just google the 6715B Keyboard and purchase one that looks like the one you want.
Jan 20, 2009 | HP Compaq 6715b Notebook PC
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
