Question about Kenmore 95002 / 95004 Electric Kitchen Range
Error Message: EO -F2-, but I don't have a manual
There's an error message, but I don't have a manual to refrence. The actual message is "EO - F2-" then it flashed E352. What do I need to do? I don't have a clue. Thank you, Shauna
  • 1 more comment
  • shauna poole Mar 04, 2007
    I tried the cancel/off button and it did come back. Yesterday I did disconnect the power, but I don't remember for how long and the message did come back. So, I think I need to get someone out to fix the keypad ribbon cable. Thank you for your help!!! I'll let you know what happens....Shauna
  • Gange420 Feb 12, 2008
    I have the same prob but on a WhirlPool AccuBake Duo. Display reads E0-F2 followed by lots of beeping. Any help much appreciated!
  • Mom is mad Aug 08, 2008
    Yes, I have the same EO F2 problem with my Whirlpool Accubake double oven. We've shut the circuit breaker down for at least an hour then turned it back on to find the same error code after a few beeps. I even tried pressing buttons (in case they were stuck). I guess we'll have to pull the monster of an oven out to check and clean the ribbon. It's a shame the unit is only 3 years old and we didn't opt for the extended warranty. If any new info for this problem please advise..... Thanks
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Posted on Jul 24, 2008
  • Miriam Lytle
    Miriam Lytle Oct 25, 2013
    Awesome this worked like a charm!! Thank you so much for the solution!!
    President:
  • 878 Answers
Shauna, you have a keypad problem here. First try pressing the cancel/off button for 5 seconds. If the code is still there, disconnect the power for about a minute and connect. If the error returns you will have to get someone to disconnect the keypad ribbon cable from the main board, clean the end with an eraser and re-connect it. Re-apply the power and see if the error returns. If the error returns, probably a bad keypad. E0-F2= stuck or shorted keypad....Catriver..post back
Posted on Mar 04, 2007
    New Friend:
I did exactly what echo1700 said. I unplugged the whole thing, waited for an hour (so, a little longer than advised), plugged it back in and held the cancel button down for 5 seconds. Ouila! It's totally fixed and I've used it about four times since then with no problems at all.
Posted on Dec 11, 2009
I have a Whirpool Accubake with the EO F2 error. I tried unplugging it, then holding down the cancel button after plugging it back in. It didn't work. So I unplugged it again, let it sit for a couple hours, then held down the cancel button before and while I plugged it in. This worked. It let me figure out which button was faulty. (It was the clock button)
Posted on Sep 16, 2009
  • gvsa123 Aug 27, 2010
    mcatan, what sort of problem with the clock button did you have and how did the procedure help you figure it out?
Thank you so much! My "boyfriend" literally blamed me for breaking the stove and how he'll have to put his cape on and "save the day". Can't wait till he see's a woman did it first!
Posted on Feb 06, 2011
SOURCE:
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
CONTINUE TO GET THIS ERROR MESSAGE EO-F2
you may have an oven temp sensor out of wack. may have carbon on it . wires going to it may have burned
Feb 03, 2010 | Kitchen Ranges
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
EO F2 Lock message on oven panel
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Dec 29, 2008 | Ovens
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Error message EO F2
that fault refers to a shorted key panel, recommended repair is to replace replace Electronic Range Control/Clock (erc)
Feb 24, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
9,200 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
