Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Laptop screen goes black ,but when charger is plugged in it works
I have a hp dv2000 laptop and the screen goes black right after the windows log in. when i press function f4 twice its okay for a minute but the outline of the icons on the desktop are a little fuzzy but however if i plug in the hp wall charger it works 100 percent and the icons are in perfect working condition and it works perfectly.
  • 2 more comments
  • assadrafaq Jan 17, 2009
    My Hp Pavillion dv2205ea behave in similar manner,....BUT not imediatly after loging in . It works for a while (30 min) then suddenly display screen goes blank even my battery is in excellent condition.
    I tried different Battery settings but problem persist.
  • ukmonkey2002 Jan 29, 2009
    I have the same problem it started ith laptop just turning itself off now it powers on all lights are on but just black screen :(
  • Anonymous Feb 04, 2009
    My HP Pavilion DV 1682 US laptop has recently developed the same issue. It can occur at any time, including when booting, during the BIOS phase of booting, therefore I think it is not OS related.
    Toggling with Fn-F4 can momentarily bring back the display. Note: An external display I hooked up always works (again no OS problem I think). Also, if I look closely at the black screen (put a light on it), I can actually see the window being displayed, so in this issue it seems to be the back lighting of the screen that has been turned off.
  • Stingrayvt
    Stingrayvt May 11, 2010
    Try turning off the computer, taking out the battery, plugging it into the wall and turning it on. See if it comes to desktop with icons normal.
    Maybe a bad battery.
    Going black before loading windows is normal for some monitor types.
    Problem Solver:
  • 13 Answers
I would call HP and see if they have a recall on their batteries as does Dell.
Hopefully if they do not , you are still covered under warrantee.
For you that your machine just turns black and the battery seems charged or you are on a power outlet, I would check your machine to see if its over heating. I would download speedfan to see what temp its running at. Here is the link:
http://www.almico.com/sfdownload.php
Click on the second paragraph where its in blue "speedfan 4.37 it will take you right to the download.
Hope this helps you and others! Good Luck.
Posted on Feb 18, 2009
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
My hp dv2000 is almost 2 years old it had been working well but a few days ago it stopped showing the screen anymore it only shows the backlight. before that it was not loading up at all. Now i can hear...
Hello. I could be hard drive failure if you keep hearing noise. What you need to right now is to backup important data ASAP. You can backup files with your Windows built-in tool or backup hard drive without booting Windows.
Choose the one you like and get a new disk. Do fresh install or restore backup image on that drive. Best Way to Backup Hard Drive without Booting Windows
Oct 11, 2017 | HP Pavilion dv2000 Series Laptop Full...
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Screen is Black hard drive works screen lights up then goes blank
The Problem is that, your system is in STANDBY mode..bring it back..
This should solve your problem..
Jun 09, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000 would not start up, black screen
try to re install first the software or program then observe if the same problem,, check the lcd inverter...
Jun 07, 2009 | HP Pavillion ZV6000 Notebook
This particular model of Hp was shipped with a bad inverter. You can check out the link below to another forum with users with the same problem.
http://forums.majorgeeks.com/showthread.php?s=2d48836d2fa4bb298f0d0f8261490630&t=108320&page=2
In order to fix the problem you just need to discount the old inverter and it should work according to what I have read. The link to the manual is listed below.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Dec 11, 2008 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
285 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
