Question about Zodiac Nature 2 Cra30 Replacement Cartridge
Cant set pool timer Model Zodiac LM2-24
Need help in setting the pool timer to come on automaticaly Zodiac LM2-24
Thank you
2 Suggested Answers
SOURCE: zodiac clearwater LM3-15
Just found the instructions for this at this address
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
worked beautifully....good luck.
Posted on Oct 17, 2008
Cant get wifi connection for zodiac iQ904 iaqualink
turn all off then back on if same open antenna and reset
Nov 30, 2013 | Zodiac iQ904-P iAqualink Pool Only
How do i set my timer for my pool pump
10-20-12
The 240Volt residential titan pool pump does not have built in timer.
So timer is installed on the electric line going to pool pump.
Copy following links to help identify timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Boxtype.html
Also add a comment and describe timer in detail for possible help.
Oct 20, 2012 | Zodiac Pool & Spa
How to put on the pressure regulator
Here is a copy of the users manual for the G3 pool cleaners from the Zodiac website. Any set up and installation instructions that you need should be in the manual.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jan 08, 2011 | Zodiac Baracuda G3 Automatic In Ground...
I have a baracuda zodiac pool cleaner and it want work. I have change the hoses check the filter all working but it still want move. The suction is strong what to do?
I have had the same problem. If you don't already have one, a regulator which sits on the end of the hose then into the round plate in your skimmer box. Settings are from 1 - 6. 1 being 100% 6 being I guess 30%. They are inexpensive. I have mine set at 4.5 and is working OK.
Dave W
Dec 18, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My zodiac is pulsating, diaphragm is clean but it stays in one place>??
It sounds like you might need to adjust the pool cleaners water pressure. You need to use your flow gauge and check it. Keeping the hose submerged, attach the flow gauge to the hose and turn on the pump. Verify that the red indicator in the gauge (viewed from the side) is at the Number 3 setting. If you flow is low, verify that valves controlling the suction lines are in the correct position.
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have the zodiac g3 i hear it pulsating but i looks like it has too much suction and it gets stuck and does not move how do i adjust it
You need to use your pool cleaners flow gauge to test for proper flow. Keeping the hose submerged, attach the gauge to the hose and turn on the pump. The red indicator, when viewed from the side, should be at the 3 setting. If the flow is too low, check and clean the pool filter and baskets. If the flow is too high, verify that valves controlling the suction lines are in the correct position, change your flow setting on the Flow Keeper valve, or open the main drain slightly.
Jul 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I need to know what setting on the gauge provided to set the value at.
Are you referring to your pool cleaners flow gauge? If so, the reading should be at a 3. If you need to raise or lower it, the owners manual (below) has specific information for doing so.
Jun 25, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac x7 quattro won't move, even with the flow set right.
unscrew the collar just above the handle and push the pipe inside downward. visually inspect the diaphragm for debris or damage. This is the most common cause, given you are confident the suction is sufficient.
Mar 13, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac clearwater LM3-15
Sep 07, 2008 | Zodiac Nature 2 Cra30 Replacement...
Zodiac Nature 2 Cra30 Replacement Cartridge Logo
622 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
