Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
H"E" code the E flashes
Hi we have a LG dishwasher LD-12AW5 in the quick cycle it gets to 14mins left and then sends a error code H "E" with the E flashing.We have checked the water pipes and the filter, please help.
  • feusche Apr 14, 2009
    diswasher displays a e1 error code
  • 423 Answers
Did your problem get resolved? What did you find was the problem?
I would have expected to see an E1 error with the symptom you described. Thanks for updating me with what you find.
Posted on Apr 10, 2009
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
178 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
