Question about Kenmore 96213 Electric Kitchen Range
Oven door Door will not shut completely
  • Anonymous Dec 28, 2007
    i have the same prob.my serial # is VF-440xxxxx, will the same hinge kit fix the prob????
    President:
  • 878 Answers
Dat, If your model starts with 790. there is a service flash regarding the hinges. Oven door not closing all the way. Affected model serial numbers VF-428xxxxx through VF-434xxxxx. There is a hinge kit for it, part number depends upon your full model number. You may want to call Sears and inquire about the service flash, you should be covered. Catriver..post back.
Posted on Mar 05, 2007
  • DOUG SOARES Nov 06, 2011
    Same problem model 790.96322401 but serial number not in the range indicated. SN: VF 45068465
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
Oven door does not consistantly shut completely
There is alot of unit that I personally repaired for the same problem. I designed a quick fix for it without changes the hinges. It is a little bit technical. The door has to be to took apart and in will need three washers on both sides of the hinge. this will be a $1.00 do it yourself fix if you dont have any coverage.nyc appliance repair can fix it for you.
Feb 02, 2010 | Bosch HGS 255 Gas Kitchen Range
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
We have GE oven. We never used the self cleaning mechanism, but the designation "door locked" is flashing and we can't complete shut the oven door because the latch is not set properly. How can we reset...
MINE DID THIS TONIGHT. I HIT THE CLEAN OVEN BUTTON AND THE DOOR LOCKED STAYED LIT. AFTER ABOUT 1 MINUTE I HIT THE CANCEL BUTTON AND THE LIGHT FINALLY WENT OUT AND I COULD SHUT THE DOOR. HAVE NOT TRIED TO COOK WITH IT YET SO DON'T KNOW IF THE PROBLEM IS SOLVED BUT THE LIGHT DID GO OUT AND I COULD FINALLY CLOSE THE DOOR.
May 14, 2009 | Kitchen Ranges
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Kenmore 96213 Electric Kitchen Range Logo
224 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
