When my computer was started in monitor display MBUltra133 (tm) BIOS Version MBUltra133 BIOS is not installed because there are no drives attached. SiI 3112 Serial ATA Host Controller BIOS Version 4.0.26. Primary Chanel : Drive 0 not found Secondary Chanel : Drive 0 not found The BIOS is disabled I am use WIndows XP SP2, P.IV 2.00 GHz, Memory 256 MB In Device Manager was display ?Mass Storage Controller Please, help me with this problem. Tq
    Problem Solver:
  • 8 Answers
If you are looking at Device Manager, the computer must be working to some degree. Since there are no drives on the SATA controller, you're probably using an IDE drive and don't need the SATA controller anyway. Disable it in the BIOS. And get more memory.
Posted on Dec 12, 2008
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
and obtain the bios and flash file for this laptop ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Screen displays low illumination.dvd drive not ok, av in ok.
Screen Display Issues:
Go to the BIOS. Once you power on the laptop immediately hold down the F2 key then BIOS will show up. Try to check in BIOS if the display has low illumination if yes then try connecting your laptop to an external monitor then toggle the display to the external monitor. If the display from the external monitor is fine then it means the LCD has issues and needs replacement. But before going into any LCD replacement try to update the BIOS version first.
DVD Issues:
Check first the DVD icon in My Computer window. If missing then kindly do this:
Delete the upper and lower filters.
Uninstall the DVD device driver from device manager.
Restart the computer.
Check BIOS if ODD or DVD is present. If yes then F12 boot to DVD if failed replace DVD drive.
If the DVD not present in BIOS replace DVD.
May 28, 2011 | Computers & Internet
Rainbow six vegas 2 running slow? This game is running really sloooooooooooooooow on my desktop computer. These are my sistem specifications with updated videocard. I already tried changing to best...
i had the same problem. First, try downloading any patches that maybe be new, they can help.
then once in the game menu, go to the options and decrease the visual effects and graphics. they made this 2nd game to run in defalt mode with HIGH graphic computers, but if you just lower things to 800x600 and then set things to low, the gaame should run better, wont be perfect, but you will be able to play it with out getting mad at
Sep 23, 2010 | Rainbow Six Vegas - PC Games
Same problem, i downgraded it to XP. Now i cant get any sound. It says ''no sound device installed''. base devices have yellow warning signs on it... what do i do? pls help? ------------------ System...
Thank you for your query
Please try the following
1) Go to and download and install the software
2) Load up the program and then click on 'begin scan'
3) This will scan and hopefully pick up the missing drivers for your sound
4) Click on download for the sound drivers
5) Install the drivers and enjoy
I hope this has been useful
Mar 16, 2010 | Toshiba Satellite A305D-S6835 Notebook
Power off automatically after 10 - 15 min
Your hard disk has crashed. Take it in to a computer store (Microcenter, Fry's, TigerDirect, or Best Buy) to get a new one. The data on your computer's hard drive may not be able to be saved.
Jun 13, 2009 | Acer Aspire 5100 Notebook
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Microphone does not seem to be working
The microphone connector is on the rear of the monitor, and you need to connect it to your computer's microphone input jack. The cable is the same kind you would use to connect the audio output jack to the input on a set of computer speakers. Once the microphone is plugged in it works just like any standard microphone. No special drivers are needed for the monitor, but you do need to be sure that the proper drivers for your computer's sound devices have been installed.
If this solution has been what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | Compaq Computers & Internet
Computers & Internet Logo
David Payne
David Payne
