Question about Thomson RP3538 RCA MICRO CASSETTE
When I use my microcassette recorder, which is only a month old, I get a loud buzzing sound in the background. I went and bought brand new tapes and the sound is still in the background. This sound was not present at the time of recording....help!
Tascam 488 Tape Recorder
Have you tried playing the tape in another device? Adjusting the recording volume if that is an option? Look for the user manual pdf online and also try a brand new or different brand tape to ensure that is not the problem.
Nov 16, 2013 | Tascam Audio Players & Recorders
My microcassette tape recorder stopped working.
It is possible that the rubber drive belt has broken or the motor is bad. Turn the volume all the way down,hold the unit next to your ear and put it into a function. Listen for motor noise, a slight buzzing noise. If you hear that it is possible the the motor is good and the drive belt is broken.
Oct 29, 2012 | Audio Players & Recorders
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Jun 07, 2010 | Sony BM-850T Desktop Cassette Transcriber...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
I transcribe from microcassettes that are recorded on various recorders. Some of my users *always* have a loud buzzing throughout their tapes making my job miserable! I'm trying to find a solution and...
One thing that can cause this buzzing is the recording machine being too close to a computer screen which can give off powerful magnetic fields at 50-60Hz.
Mar 11, 2009 | Audio Players & Recorders
Won't rewind microcassette recorder
Although this unit may look new, it is over 10 years old. The problem is probably that the rubber belts and drive tire are bad. They can fail even if never used. I would suggest replacing with a newer model.
Dec 31, 2008 | Olympus DS-2300 Digital Voice Recorder
The recording fades after a few months . I can hardly hear.
ok
1.you handle micro cassetes safly (foraway from havey magnets and speakers.)
2. before recording your lession (clean your tape R/P head for remoeing dusts and all)
3.if not ok replace your tape R/P head witrh new one.
Nov 13, 2008 | Electronics - Others
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Thomson RP3538 RCA MICRO CASSETTE Logo
Top Thomson Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
