Question about Nintendo Wii Console
Problem with my Wii remote
One of my wii remote stops working eventhough after changing batt or pushing resync buttons. There simply no light flash on that remote. The battery works fine with my other remote. Do you any idea what's wrong or it is broken? I suspect it got overheated from my desktop charger where i put both of my remotes for charging my rechargeble batt.
Please help
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
Whilst using the wii to go online my son said the wii remote just stopped working so thinking the batteries were low he put it back on the docking station & left it to charge up. Yesterday when I went...
Try buying a new remote.or press the sync button on the wii console for 15-20 seconds then resync all controllers in the wii one by one.hope this helps Julie Dentith. :)
Apr 15, 2011 | Nintendo Wii Console
On my wii remote at the bottom of the remote belong 1&2 them lights all flashing and it will not pick up we change the batties still not working can you help me..
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
Nov 29, 2010 | Nintendo Wii Console
Put new batteries in the remotes and the four lights blink twice when you push power
You might have to resync the remote take off the battery cover and push the red button under there to resync it with your wii, you will have to do the same thing with a brand new remote or when taking the remote from one wii console to a friends.
If this isnt working then your remote batteries are bad or you are having a hardware issue with the remote. Unless your trying to play a game cube game this is another issue and has nothing to do with your wii remote working or not.
post back if this dont fix your issue
Apr 23, 2010 | Nintendo Wii Remote Controller
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
I am having probelms getting the board to sych with the box please help !!!!
Simply turn on your Wii. Using the first player remote press the home button then go to the bottom of the screen and you'll see the controller sync screen. You should then see like a resync or something similar. Hot that and the Wii will make two ringing sounds. When this happens press and hold the 1+2 buttons on the remote and then after it connects press and hold the sync button on the Wii Fit board where you insert the batteries.
Feb 01, 2010 | Nintendo Wii Fit for Wii
My wii remote won't connect to my friends wii but connects to mine just fine
You will need to resync the remote back to your wii. Take off the battery cover and open up the flap on the front where you put a memory card in. Push the red button by where the batteries go on the wii remote and the red button above where the memroy card slot is, both the wii and wii remote should flash and eventually the first light on the bottom of the wii remote should flash indicating a successful sync.
Dec 29, 2009 | Nintendo Wii Console
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Jul 04, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
163 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
