Question about Yahoo Messenger
My yahoo Im stops working
Everytime i try & log on a window pop up sayind the program stop working....what up?
  • grneyes2kool Dec 12, 2008
    thank u very much..but will i lose my contacts?
    Problem Solver:
  • 16 Answers
No they are stored online not your pc. but to be save copy your contact list to a folder in my documents
Posted on Dec 12, 2008
    Problem Solver:
  • 16 Answers
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here;
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. This one for Vista
many problems solved using this link
Posted on Dec 11, 2008
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
Yahoo messenger v10 crashes with vista.when you sign in after the sign in a window pops up stating "yahoo messenger has stopped working check a solution on line and close the programe
Just un-install the program first , then re-install it again, i am using Vista Ultimate and Yahoo messenger 10, and it works fine
Nov 05, 2009 | Yahoo Messenger
Can't pull up anything once logged in (eMachine W3609 is the mod)
in the run type msconfig then press enter. A box will appear and click selective start up. Then next to tools on the top click on startup. Look for the entry that shows up and disable it. restart and she if that helps
Sep 26, 2009 | E-Machines eMachines Desktop PC
Can't open certain windows after trying to install Itunes
Encarta is actually Microsoft's Encyclopedia ( Did you try uninstalling iTunes at all?
Mar 21, 2009 | Apple iTunes
Application crash
i was trying to login on My BDO Internet Banking and the website is crashing everytime i open it...
here is the application error...
Problem signature:
Problem Event Name: APPCRASH
Application Name: iexplore.exe
Application Version: 7.0.6001.18000
Application Timestamp: 47918f11
Fault Module Name: StackHash_fd00
Fault Module Version:
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 03590cc6
OS Version: 6.0.6001.
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
can anyone help me please....i appreciate it!!!
Oct 23, 2008 | Yahoo Messenger
Yahoo messenger has stopped working
I have gotten this issue several times being a tech for the HP notebook division and I found a simple solution for it.
Right Click on the Yahoo! Messenger icon on the desktop and select properties.
Click on the Compatibility Mode tab
Check the box at the top to enable it and make sure the mode is Windows XP SP2.
Select ok.
Restart machine.
I hope this works for you all. =)
My yahoo messenger has stopped working
hi , i also had the same problem, but i was able to fix it. dont know if its only for a while.
what i did was i uninstalled then installed Yahoo messenger . . then right click on the yahoo icon and select administrator . then the YM will pop out but still you cannot log in .
i then started to update my norton antivirus and then after it had installed the updates, restart your computer. after that dont know how it happened but it was fixed. i can log in
hope this helps
Oct 13, 2008 | Yahoo Messenger
Messenger sing in problem
I would recommend first attempting an uninstall and reinstall of the program on the computer giving the issue.
Oct 03, 2008 | Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name:
Fault Module Timestamp: 459bb828
Exception Offset: 00008b89
OS Version: 6.0.6000.
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Yahoo Messenger Logo
203 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
