Question about Mach Speed (S755) Motherboard
No HDD Found on initial XP Install
Ok...what I have is this: New system build, using a Mach Speed MSNV-939 mobo, AMD 64 4800 cpu, WD 250G SATA, Ultra 1G PC3200 DDR 400 Mhz (x2), 450 W Case...Problem is this: During XP Pro install...makes it to the point of showing the hard drive to install to but shows "No Disk Installed" on screen. When i press enter, C or D...it Blue Screens on me giving a 'setupdd.sys' file error. I have the SATA driver disk and loaded the two drivers...I have the SATA data cable, SATA power and legacy power connected. I have even disconnected Legacy power...tried different cables, configuring differently, different SATA disks, different XP disks...nothing!?! Any and all thoughts would be greatly appreciated!
  • Jerry Ham Mar 04, 2007
    Yeah...guys...thanks for the comments...but I have already installed the SATA (Raid) drivers. I used the ones from the mobo CD...and I went out and grabbed some newer ones from both the Mach Speed site and the nVidia site. they all load off the floppy just fine...but then XP loads some more files and brings you to the next screen where you hit ENTER and then the Agreement screen where you hit F8...then the very next screen it shows no HD installed. I checked the bios...the drive shows up in any of the 4 SATA slots available that I plug it in to...its listed as the first boot drive...I'm beginning to think I have a bad HD...I just took it and connected it on another system which is already running XP, SATA HD, etc...and it doesn't recognize it there either???
    More thoughts??
    Thanks again!!!
  • Anonymous Jan 14, 2009
    i have amilo pro v 8010 i tried to install xp pro it disolayed NO HDD FOUND ...if any one has the solution..then mail it to me ..mutal lib_96@yahoo.com
  • 196 Answers
I googled this setupdd.sys' file error, and it seems to be a hardware incompatibility, not limited to PCI or memory issues. Take a look here: http://support.microsoft.com/kb/330181 What is the exact error message?
Posted on May 30, 2007
HDD needs to Partitioned and formated to be found
Make floppy for SATA, when start instlling Windowz press F6 and this is it!
Posted on Mar 12, 2007
On my board the SATA ports are mislabled. SATA4 was really SATA1, SATA3 = SATA2, etc. Watch what driver show up in the post screens.
    Sergeant:
  • 310 Answers
Yeah it sounds the sata disk, ie when you restart the pc, it starts booting off the windows disk, you need to keep pressing F6 it will then appear a screen asking you to put in the floppy disk with the sata drivers for your motherboard, if you dont have the floppy disk, if you browse the Motherboard CD that you got with the board, you should find a sata folder with a little utility to make a floppy disk with the drivers on it.. All the best John
Posted on Mar 04, 2007
    President:
  • 2,961 Answers
Did you insert the sata driver disks when prompted in the first stages of installation? I think it's mentioned as scsi drivers.
Will it run 64 bit os?
Visit http://tiger.tv/more_info/?288 for more on this great motherboard. Mach Speed's new MSNV-939 motherboard
Nov 05, 2011 | Mach Speed (MSNV-939) Motherboard
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
Mach MSNV-939 motherboard - RAID 0 - How to setup?
im in the same spot... di anyone found this sol. ?
Apr 10, 2008 | Mach Speed (MSNV-939) Motherboard
LAN problems on Mach Speed MSNV-939 motherboard
Sounds like you havent loaded the network driver yet.
Right Click My Computer
Click Properties
Click Hardware
Click Device Manager
Got some yellow devices?
Then you need to download drivers to the pc and install them.
Device Drivers
Oct 12, 2007 | Mach Speed (MSNV-939) Motherboard
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
Hdd problem
it's not often you need to use cable select, but if you have had to use cable select on one of your drives, your other drive would have to use cable select, but you may need to check in the bios F2 or Del on start up and in the list of drives you should be able to press f12 or similair to auto identify the drives, then save and exit.
Jun 10, 2007 | Mach Speed (S755) Motherboard
Viper MSNV-939 ATX Socket 939
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop. Also assuming you bought the ram from the same place and is compatible with the board. Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual. The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip. That's not to say that the motherboard was'nt faulty in the first place.
Apr 18, 2007 | Mach Speed (S755) Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Mach Speed (S755) Motherboard Logo
577 people viewed this question
Top Mach Speed Computers & Internet Experts
Marvin
Marvin
Abhinandan  Patil
Abhinandan Patil
M_Butkus
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
