Magic Chef CYE4000AWW Electric Dryer
Problem for Magic Chef CYE4000AWW Electric Dryer
Gas Dryer won't heat - Kenmore model 11070202990
By dybarra_fami on Dec 11, 2008
Cleaned behind the dryer and in the lint hose. Dryer will not heat.
Solution #1
posted on Mar 08, 2009
Not Rated)
oneseven73
Rank: Apprentice
Rating: 0%, 0 votes
Try checking the thermal fuse on the back of the dryer. Take the black cover off first, its mounted nest to the gas flue. Its a $12 US part to replace, but test it with a circuit tester to be sure.
Was this helpful?
Yes
No
Solution #2
posted on Dec 11, 2008
Not Rated)
codfish124
Rank: Wiz
Rating: 91%, 28 votes
did you kink or turn off the gas valve? the igniters can be fragile some times and the slightest bump can break them. open the access panel in the front and see if you have a red glow if not then check it for power
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CYE4000AWW Electric
Questions and Unsolved Problems for Magic Chef CYE4000AWW Electric
Do you recommend Magic Chef CYE4000AWW Electric Dryer?
Answer
Answer
magic chef ye225lv electric dryer model#11440683uf makes noise when turn on and drum seem loose
Answer
It wont start. I had the high temp, door switch, and other sensors checked. There was a blue wire on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
