Question about Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit
Hello, I have a dewalt drill cordless 12V. I have taken the casing off and want to know how I want to know how I get to the brushes. It has stopped working and suspect that it is the brushes. I am not mechanically inclined but live in a place where reliable honest mechanics are hard to find. I live in a 3rd world country
    Scholar:
  • 58 Answers
I fix cordless DeWalt drills every week!Look for two black carbon-like blocks found on either side of the commutator ( the central spindle ) they will each have one wire on the outside end attached to a spade connector so the brush can be easily removed by prying it out from beneath the spring holding the brush against the commutator.  Then the wire can be removed and the new brush installed.    Go online to http://www.toolpartsdirect.com and search for your model dewalt drill. they have an exploded diagram and parts listing for each model drill.  That will identify the brush for you if you have never seen one before.    If the drill was operating intermittently with lots of noise and usually blue sparks coming out, loss of power, increasing intermittant operation it would almost certainly benefit from replacing the brushes.   If it is simply dead, and was ever dropped.  check the battery terminals and the trigger mechanism.  Of course inspect the battery and check inside the drill for loose or broken wires and connections. I hope this is helpful. Good luck!
Posted on Dec 11, 2008
I purchased brushes for my 12 volt dewalt drill yesterday at the Dewalt warranty store in Denver. Today I took the housing off the drill and it does not have the same type of brushes in it as the...
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
Mar 24, 2011 | Dewalt DC727KA 3/8" 12v Cordless...
I have two 18v DeWalt cordless drills that I have USED A LOT -- can I replace the motor pack?
If your mechanical/electrical knowledge is up to par, then yes. I'm not sure what the cost would be..but I've taken apart a few drills and replaced brushes, lubed bearings, etc.. They are fairly simple..although I know those XRPs are tanks..you must have put it through some insane force to break it. You may want to check with the warranty on them though...my friend has gotten a few, free, replacements though the depot.
Sep 26, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
527 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
