No sound New monitor and I have no manual to tell me what to do to turn on the sound, when I turn it on it makes a ''sound'' but that is all
  • Nashea Jan 14, 2009
    There is no sound coming out of my monitor.
What kind of monitor is it? What kind of sound is it?
Many companies will let you access and print out their manuals for free online if you input your model and make on their website. Search under "manuals".
Also, the HP w22 LCD I have has internal speakers whose settings and volume levels are controlled through the buttons on the front bottom of the monitor. The monitor has a 'PC Audio In' jack on the back side, which is used to input the digital signal from the back 'audio output' jack of the computer desktop. This HAS to be plugged in with a specific audio cable to power (transmit the digital signal to) the internal speakers.
Check your settings for your external speakers by clicking on 'control panel', then 'hardware', then 'speakers' (IF your computer has located them, meaning that they're plugged in with their driver downloaded). You should be able to configure the speakers and test them for sound.
Windows may have a 'volume mixer' on your taskbar that controls the levels of your Windows application sounds, your device (speaker) sounds, and the Media Player(s).
Posted on Dec 11, 2008
Samsung monitor makes a crackling sound and turns off
just chk all the capacitors...100% fault of capaiter and chk for any ic overheat tooo..
any prob...just. tell me..
Aug 16, 2017 | Samsung 2443BWT-1 Black 24" 5ms Widescreen...
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
Jul 08, 2010 | Summer Infant Day & Handheld Video...
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | HP Q1859 18 inch Monitor
Speakers not working
I haven't seen a monitor that needs drivers for the speakers.
Assuming it has a standard 3.5mm plug for sound input from the PC, have you plugged this in between monitor and PC?
The monitor will have a volume control, make sure it's not muted or turned down too far.
Also check the volume control panel on the PC to make sure it's not muted or turned down.
Apr 06, 2010 | Mag Innovision LT776s 17" LCD Monitor
Can't get sound on monitor
First make sure that your speaker wire is plugged in to the correct port on your computer.
The speakerwire should be plugged into the green port.
Then make sure that the volume is turned up on your monitor.
Then on your computer.
If this is isolated to only your new monitor and the above solutions do not work there is likely a problem with your new monitor's speakers.
Cheers!
Feedback is appreciated!
Dec 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
My computer won't come on
Since I do not know how much experience you have I can only assume that you have the experience of a beginner or a new user, so forgive me for being obvious.
Check these items first...
(1) Make sure that the computer is plugged into a live wall socket.
(2) Make sure that the monitor, keyboard and mouse are plugged in.
(3) Turn on the power to the monitor and the computer.
(4) Look for lights on the computer and listen for sounds from the computer.
If You get no sound or lights you have a dead computer it is most likely the power supply.
Without more info it is hard to tell... It might help if I had the make and model of the computer.
Nov 22, 2008 | Computers & Internet
I bought a new computer and my existing Samsung 24 inch flat screen monitor doesn't work with it. I see 6 buttons on the front of my monitor but I don't know how they work. Unfortunately, if a manual came...
If you have the (white connectors) DVI cable correctly plugged into the computer, when you turn the computer on, it should recognize it and make the needed changes automatically. Maybe not if the PC was already on even though it's plug&play.
If you have the model number of the monitor, you can google for the manual.
Jul 25, 2008 | Computers & Internet
Princeton Monitor blackout
May I know how do make sure the connection is ok.. the only way to do is to use a known good monitor and connected to your system... this will tell you if you need a new one or not...
Aug 30, 2007 | Princeton Digital LCD1510 15" Flat Panel...
Computers & Internet Logo
622 people viewed this question
David Payne
David Payne
