Question about Linksys Wireless-G Broadband Router
Ok i need help on setting up my router so that my internet is working fast without having to be plugged up to a modem.
  • TrytoFix01 May 11, 2010
    Are you asking for your router to not be hooked to the modem or your computer?
    Problem Solver:
  • 8 Answers
If your asking for help setting up your router,
Unplug the power to the modem, plug in the ethernet/network cable to the cable modem and then to the internet/wan port on your router
plug in the network cable to one of the four lan ports on the router into your computer.
plug in the power to the modem first, wait till the internet/online light goes solid, about 1 minute, then plug in the router to power wait 30 seconds.
You should be good.
To program the router open up internet explorer and in the address bar type in 192.168.1.1 press enter or click go
password by default is username is empty or blank, and password is admin
Posted on Dec 11, 2008
Can connect to router but not internet
Ok so the router will broadcast even without an IP from the modem. Without the IP even though your pc is talking to the router you will have no internet. The IP is assigned to the modem from your ISP "internet service provider" The router has to assume the IP then assign a mac address to the pc using the internet. A residential modem meaning your not a business is given a dynamic IP which can change at anytime the blade server wants it to. A business gets a static ip which never changes. There lies your issue. Whats happened is your modem has been assigned a new IP and the router is still trying use the old IP. So unplug your modem and router. Plug the modem back in and let it sync up. Once all the lights are back on "with exception for the "link" light plug the router back in give it a cpl minutes your internet will work again.
Apr 03, 2014 | Acer Computers & Internet
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
Cannot connect to my wireless router
If you connect the computer directly to the modem, it works .
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 19, 2009 | Computers & Internet
Having a problem with my belkin router and need some help ... please! All of a sudden this afternoon the Modem light started flashing yellow and our internet has been down. I have checked all of the cords,...
If you connect the computer directly to the modem, does it work?
It is very easy.
Dec 17, 2009 | Belkin F5D8236-4 Router
Won't logon to internet through the router...
It is very easy.
Dec 16, 2009 | NetGear Cable/DSL Router with 10/100 Mbps...
Belkin f5d8233 4v3 won recognize my modem
Hi! I will be more than glad to assist u in this concern..That is right! if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 26, 2009 | Computers & Internet
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
