Question about Kitchen Ranges
I have a frigidaire #fef355asg electric range. The burners on the left side do not work. Replaced the elements , still no heat and lights do not come on by the knobs. The 2 burners on the right side work fine. any help?
  • 36 Answers
Check for power at the burner if none there take off the top back panel and check for power at the switch coming in and going to the burner. if you have power in and not out then the switch need to be replaced (i like to change all 4 as a set). if there is no power going into a switch then trace the wire back to a broken wire good luck
Posted on Dec 11, 2008
The front left range element on our frigidaire electric range es300 does not appear to be heating at all. The unit's "Element On" light turns on, but the element itself does not come on. Eve
Good afternoon friend, thanks for your inquiry!
Based off the information you have provided me regarding your Frigidaire range element not working I am able to identify some possibilities with your range. It could be an issue with your burner switch or burner element. It would be best to have a professional come out and properly diagnosis your appliance to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Oct 05, 2014 | Frigidaire FEF368GM Free-Standing 30-Inch...
Frigidaire FEFB78DCD range wont heat but display and lights work
you need to check all the wiring.the main control board should be replaced.
Feb 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Burner not working
This is an easy repairr and you can save a lot of money by doing this yourself. This sounds like your infinite switch burned your burner element out and you CAN do this!
Just contact us at:
from 7AM until 7PM CST and we will provide part removal/installation instructions when you purchase your parts through us.
We look forward to getting your range top cooking properly again soon, so call us when you need us.
Thanks, Ella :)
Dec 29, 2009 | Kitchen Ranges
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
May 17, 2009 | Kitchen Ranges
Rear element will not get hot . has been replaced and has electric up to the element when turned on
Check the receptacle you burner plugs in to. There are only three items to a burner. The switch, supply power. The receptacle where the element plugs into and of course the burner itself. You say you replaced the burner and has electric up to the element. How are you testing this voltage? Perhaps you are only reading 110 volts and your burner needs 220 volts to operate. Double check these item s and let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 18, 2009 | Tappan TEF242 Electric Kitchen Range
Left front burner
It has a bad element that needs to be replaced
Jun 09, 2008 | Frigidaire FEF376 Electric Kitchen Range
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
