Question about Pioneer PD-F908 101-Disc CD Changer
My cd player isn't reading the discs, I've got power it will change cds every thing appears to be working until the cd is ready to play. What can I do?
  • ab28 Dec 29, 2008
    my cd player won't play my cd's
  • 899 Answers
If you have already used a laser lens cleaning cd and it will not read that either , then a manual cleaning of the lens will need to be done , its probably just can't see well right now
Posted on Dec 11, 2008
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
Jul 28, 2011 | Pioneer PD-F906 100-Disc CD Changer
The CD player does hardly read self- burnt audio CDs although every one of my other cheap Players i have at home or in the car can read them.
The answer depends upon the age and precise version of your Bose system. Not all CD players can reliably read CD-R and CD-RW discs, and even those which do are sometimes picky about the brand of recordable disc in use.
In my experience, all of the Bose Wave systems I've worked on have contained surprisingly cheap/average parts inside considering the luxury price-tag. Either stick to using other cheaper (and often far better) CD players for CDs you've burned yourself, or look into getting the CD laser pick up inside your Bose replaced with one which is known to have no issues with CDs of different reflectivity to standard pre-recorded CDs.
Jul 06, 2011 | Bose & Wave& Music System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
When i press cd on my radio it constantly says reading on the screen but no sound is coming out.i have a classic beetle and it needs music
The problem normally is to the reading head. You have to open the player find the head and clean it with a cotton stick very gently. Then try to listen a cd. If it works it's ok, or else your head is broken and you have to replace it thing that I am not suggesting because of the high cost of the head.
Oct 07, 2009 | Kenwood KDC-C667 6-Disc CD Changer
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Stuck CDs
If you don't care about the disc player and want to get the cd's out you can easily take it apart yourself[make sure you unplug it]
Dec 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Pioneer PD-F908 101-Disc CD Changer Logo
295 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
