Question about WYSE WT3235LE (902032-68) Network Terminal
Does other terminal emulation VT220/VT100 work on WYSE?
The two products mentioned, running on Windows CE.NET and terminal emulation 5.0.1. Was wondering if we can skip the citrix metaframe virtualization and use a fundamental VT100/VT220 terminal.
Vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Posted on Nov 25, 2009
AT-8000GS/24 reset password with out reset button
Forgot or lost the password
Contact Allied Telesis Technical Support for assistance.
Apr 22, 2014 | Allied Telesyn ?AT-8000GS/24PoE 24-Port...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
How do i network my home pc with a wyse terminal.
OK,
That makes sense.
1. Physical network - Depending upon the distance between the terminal and the PC you have the choice of either wired or wireless. It is probably easiest as you have wired cards in both the PC and the terminal and the PC to buy a LAN switch, or use ports on your DSL router (I am assuming that they are also connecting out to the Internet?).
so, plug the PC and the terminal into the switch/DSL router using CAT5 Ethernet cables (straight through ones).
Assuming that you have a DSL router that is handing our DHCP addresses, ensure that both the PC and the terminal are both getting addresses via DHCP. You can easily check this by opening up a command (DOS) window and typing ipconfig. Check that you have an IP address on both boxes (typically 192.x.x.x or 10.x.x.x ranges unless default DSL router config has been changed). In the DOS window on the PC type "ping <remote address you got from terminal>" - you should get a response back if all is well.
2. Now you have connectivity between the PC and the Terminal, you need to get a remote desktop capability if I understood you correctly?
You could use either Windows remote desktop (in XP it is called something like remote assistance). I prefer VNC as it is quick, lightweight and free. You can google this and download both server and client apps.
This should get you into a situation where you can remotely control / view your PC desktop on your terminal. You can of course map drives from one to another.
Let me know if the above needs additional clarification, if it helps please leave feedback accordingly
Cheers
Jan 24, 2010 | WYSE Winterm 3235LE Network Terminal
Print Screen on a Thin Client
PrintScreen dont work!
Use the free program, ex. Gadwin PrintScreen
Jun 30, 2009 | WYSE S10 (90210501) Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
PAssword Recovery for Allied Telesis 8000s
try
usename: manager
password: manager
also try
usename: manager
password: friend
Mar 12, 2009 | Allied Telesyn Computers & Internet
Cannot read symbologie/BarCode: i25(interleaved 2 of 5) from an MC9090-G running VT100 emulation. How do I configure the scanner within Telnet-CE/Wavelink?? Thanks. Dante Barboza
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Jan 06, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
Reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
Dec 08, 2007 | WYSE Winterm S30 Network Terminal
WYSE WT3235LE (902032-68) Network Terminal Logo
212 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
